Old 12-09-2010, 06:40 PM   #1
60ratrod
yes, i do
60ratrod's Avatar
steering gear box question
so for some time i have been wondering how hard it would be to swap over a power steering gear box from a later model truck like an 88-98 truck over to my 72 gmc. my 72 already has power steering, its just that i like the stiffer power steering of the newer trucks rather than the effortless power steering of my 72 gmc. thanks
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 12-09-2010, 07:56 PM   #2
Hubscrub
Cruzin
Hubscrub's Avatar
Re: steering gear box question
just throwing this out for a thought- my 97 has a sensor that is on the steering column that i had to replace with it unpluged the steering way wayyy light it does something somewhere to make it feel stronger its a PITA when it messes up driving wise AGAIN JUST SAYIN
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 12-09-2010, 08:38 PM   #3
60ratrod
yes, i do
60ratrod's Avatar
i just hate how light my steering is on myn 72 compared to my 01 tahoe. i just want a bit of a stiffer feel to my steering is all and i thought a gear box from an 88-95(maybe) would do the trick.
Old 12-10-2010, 06:53 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the amount of power assist is in the pump, not the box.
Remove the line from the high pressure side of the pump (the steel line fitting)
then remove the fitting that is left there, a spring will pop out with a filter. Clean the filter and install a stiffer spring from a junkyard vehicle.
Old 12-11-2010, 12:03 AM   #5
60ratrod
yes, i do
60ratrod's Avatar
what vehicles should i be looking at andy? like the newer trucks/cars or like a one ton? and is it possible to get one of those springs new from a parts house?? but that's awesome news that that is all i have to do
Old 12-11-2010, 07:57 PM   #6
Longhorn Man
what ever GM car/truck you want it to steer like.
Old 12-11-2010, 09:04 PM   #7
60ratrod
yes, i do
60ratrod's Avatar
so i can get the spring from say an 88-98 and would be fine? i really do like the stiffer feel of the newer cars/trucks
Old 12-12-2010, 04:44 PM   #8
Longhorn Man
should work
Old 12-12-2010, 05:47 PM   #9
60ratrod
yes, i do
60ratrod's Avatar
sweet! now i have something else to look for when i go to the yard next. i'm gonna convert my cab to heat only and i'm gonna try to find a heat only cab to rob the ducting and controls from. thanks andy! i really appreciate it!
Old 12-12-2010, 11:52 PM   #10
Wrenchbender Ret
Changeing that spring will not change the feel of the steering.
Wrenchbender Ret is offline   Reply With Quote
Old 12-13-2010, 12:16 AM   #11
60ratrod
yes, i do
60ratrod's Avatar
ok then what will?? the entire pump?
Old 12-13-2010, 02:47 PM   #12
Wrenchbender Ret
The intire gear box.
Old 12-13-2010, 03:37 PM   #13
60ratrod
yes, i do
60ratrod's Avatar
Ok, so now i'm getting some conflicting info. Anyone else have imputs? Ticker, captain, cableguy? Changing the gear box is fine, but i would like to know for sure.
Old 12-13-2010, 03:48 PM   #14
OhOneWS6
OhOneWS6's Avatar
I replaced my steering gear with one from a 73 - 78. It was a direct bolt on. It is 3.5 turns lock to lock VS 4.5 on the 72 gear. It feels stiffer. You can use the gear from 79 - 87 as well but it has metric o-ring fittings. You either need adapters or the lines from the later model if you use the 79 - 87 gear.
I did read some posts where people said it will not turn as sharp with the later gear. That is not the case with my truck. It turns all the way to the stops on the control arm with either gear. There is no difference in turning radius. I did use the 72 pitman arm.
OhOneWS6 is offline   Reply With Quote
Old 12-13-2010, 05:30 PM   #15
Longhorn Man
my truck has a caddy engine in it, and on that engine is the steering pump off the same eldorodo. When I first did the swap, the steering was way over assisted. sping the wheel and let go and I swear it woulda kept on turning. Gave you no feedback of what was going on under the truck. I was told that this spring was too weak, and possibly broken. The weaker the spring, the more assist you will get.
I then took he spring out of the pump that was bolted to the Pontiac 350 that was in the truck when I got it. Upon doing that, and nothing else, the assist level was reduced, and feedback was improved a lot.
Maybe the spring won'd to anything... but is sure did on mine.
Old 12-13-2010, 07:36 PM   #16
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
You need more caster. Have your truck re-aligned with 3-3 1/2 degrees caster and it should feel a lot better.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 12-13-2010, 09:11 PM   #17
OhOneWS6
OhOneWS6's Avatar
That is interesting. I may have to try swapping that spring in mine.
Old 12-14-2010, 02:55 AM   #18
60ratrod
yes, i do
60ratrod's Avatar
As andy put it i am getting too much assist. I want less assist. Since swapping the spring seems the easiest thats what i'll do first
Thread Tools
Display Modes
