Old 12-13-2010, 06:45 PM   #1
cruize2000
Super Trac Bar Install...how do you center the rear wheels?
I'm getting ready to install a new Super Trac Bar after installing 4" drop coils. What does it mean to "center" your wheels and how do you do it? Thanks for any info!
cruize2000 is offline   Reply With Quote
Old 12-13-2010, 06:51 PM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Super Trac Bar Install...how do you center the rear wheels?
it means to center your wheels with the frame....so the diff is in the middle in relation to being off to the left or right...and you have the same measurements from center line/frame/mounting pts. to the back of each wheel.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 12-13-2010, 06:55 PM   #3
robnolimit
robnolimit's Avatar
Get it even side-to-side. Just measure the distance from the frame rail to the sidewall at ride hieght and get it equall.
robnolimit is offline   Reply With Quote
Old 12-13-2010, 07:05 PM   #4
Cole Trickle
C-10 Club Member
Cole Trickle's Avatar
I measured and installed mine where I thought it would be centered. Once my new wheels arrived I went back and tweaked it until it was perfect to prevent rubbing.
I installed jackstands under the frame just before the trailing arms. I then used a jack to life the wheels off the ground and pushed it over with my legs until it was spot on.
No biggie but it might take you a couple tries to get it perfect.
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels
1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold
Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910
Cole Trickle is offline   Reply With Quote
Old 12-13-2010, 07:11 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
A nylon ratchet strap helps to pull the rearend and hold it,... while you adjust the end link of the track bar.
I usually set the rear axle tubes on jack stands and pull the frame left or right.
This works pretty easy and "dulpicates ride height".
Keith
Convert to disc brakes.
Old 12-13-2010, 08:18 PM   #6
Andy4639
Old member
Andy4639's Avatar
Talking Re: Super Trac Bar Install...how do you center the rear wheels?
Jackstands and a rachet strap and a helper. Measure the side to side and hook the strap to the frame and pull it over to the center and then put the bar in.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-13-2010, 08:31 PM   #7
bsteele
Do you put the front and rear on stands or just the rear?
bsteele is offline   Reply With Quote
Old 12-13-2010, 10:46 PM   #8
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Super Trac Bar Install...how do you center the rear wheels?
I put the stands under the far back side of the frame right under the tailgate.
Then use a floor jack to pick the rear up and center it.
Old 12-14-2010, 07:40 AM   #9
dznucks
dznucks's Avatar
Why do you need to jack the truck up? Isnt the bar adjustable at both ends?
I centered mine with the truck at ride height and still on the ground. with the jam nuts loose you can turn the track bar by hand to center the rear.
dznucks is offline   Reply With Quote
Old 12-14-2010, 10:22 AM   #10
lolife99
lolife99's Avatar
No.
The ECE Super track bar is only adjustable on the end that connects to the passenger side trailing arm.
Keith
Old 12-14-2010, 01:05 PM   #11
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Set the jack stands under the truck's rear end. The rear end needs to be under load befor you adjust the track bar. Remove the wheels and tires for easy access to the frame and rear end back plates. Measure from the back plates to the exact same spot on frame on each side to find out witch way you have to pull the truck. Then hook up the ratchet strap and pull the truck to center over the rear end. Mount the track bar making sure that it the bolts go through without having to push or pull it in place. Put the tires and wheels back on and set the truck back down on the ground. I always check the measurements again after the truck is back down to make sure the rear stays centered. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 12-14-2010, 01:14 PM   #12
lolife99
lolife99's Avatar
BEST instructions on here. ^^^
Keith
Old 12-14-2010, 01:41 PM   #13
Classic Heartbeat
Thank you lolife99.
Can you tell that I have done it a few times? WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 12-14-2010, 01:53 PM   #14
lolife99
lolife99's Avatar
Thank you lolife99.
Yes. Ha.
I've installed about 5 of them.
I use to think they would be a better product if they were threaded on both ends.
(So you could adjust them connected to the truck)
But really,... after they are set,... there is no need to re-adjust them unless you change springs.
Keith
Old 12-14-2010, 05:41 PM   #15
cruize2000
As always, I continue to learn from you guys! Much apprecation for ALL the responses!
Thread Tools
Display Modes
