12-15-2010, 01:17 AM | #1 |
53 cab on 73-87 stepside 4x4
I have a 1953 pickup and wanted to make it a 4x4. I was thinking of just putting the cab on a 1973-87 4x4 stepside frame and leave the bed. It seems like the 73-87 stepside bed is similar except the fenders. Anyone know about that? This way all I need to do is figure out mounting the cab on the newer frame.
Any input will be appreciated. I know there have been others who used the blazer frame, but I want to keep the length of the bed. Gonna be my work truck. Thanks |
12-15-2010, 04:01 AM | #2 |
Re: 53 cab on 73-87 stepside 4x4
I am in the process of doing the same. i have a 76 that i just stripped down to the frame, hopefully mocking up the 58 cab soon. I'll keep you posted on how everything works out. it'd be appreciated if you did the same, this is my first time doin somethin like this as well.
1976 K10 Step-Side. 6/4 lift on 37" open countrys. jsimotorsports.com |
12-15-2010, 12:04 PM | #3 |
i think for the 53 pick up people use the blazer 4x4 frame because of the shorter wheel base..
12-18-2010, 10:49 AM | #4 |
I have one on the 1980 Blazer frame
it makes a perfectly proportioned pickup mine has a ZZ- 4 700R4 with a non lockup[ converter near stock stall and 10' wheels Gene Sharp Last edited by Gene Sharp; 12-18-2010 at 11:01 AM. |
12-18-2010, 11:34 AM | #5 |
6>8 Plugless........
Sweet truck Gene!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
12-18-2010, 11:38 AM | #6 |
Gene Sharp:
I assume you had to move the axles a bit and extend the chassis - the places I've looked show the Blazer wheelbase as a bit shorter that the AD...
Caleb |
12-18-2010, 02:20 PM | #7 |
No
the axels are in stock location the fenders require a slight amount of trimming and the front of the bed is shortened quite a lot but looks even better gives it a short powerful look you can e4ven order bed sides what ever length you need from Markay Gene Sharp Last edited by Gene Sharp; 12-18-2010 at 02:20 PM. |
12-18-2010, 08:52 PM | #8 |
Do you have any more pictures of the truck. Looks great. I was considering a shortbed pickup so I can utilize the full length of the bed and it would be less work.
12-23-2010, 08:30 PM | #9 |
soon as the holidays are over will post pix
am slso doing 56 on 80 4x4 frame that is similar to some degree Gene Sharp |
12-23-2010, 08:38 PM | #10 |
[QUOTE=Gene Sharp;4366964]soon as the holidays are over will post pix
am also doing 56 on 80 4x4 frame that is similar to some degree this is the 80 frame it is about an inch longer that ehe 56 frame we welded in pieces to fill in the dip where the 80 cab set with the blazer frame you will end up witha shorter bed Gene Sharp |
Thread Tools | |
Display Modes | |
