12-16-2010, 02:11 PM | #1 |
1966 GMC carryall side windows
I started retrofitting this 66 GMC carry-all in the spring. The rig has been sitting for almost 20 years and the engine and drive train where completely seized up. I had a wrecked 89 suburban and it made good since to swap the 66 body onto the 89 chassis. When I removed the sliding side widows, the frame assemblies completely fell apart with rust and cannot be repaired. I have pop-riveted some sheet metal in temporarily but would like to put the sliding windows back in. (glass is good) If anyone has any suggestions or knows where I can find some frames please let me know. Thanks! –Wayne-
12-16-2010, 06:45 PM | #2 |
chevy only
Re: 1966 GMC carryall side windows
I have two full sets of windows plus frames, do you still have the trim around the windows?
CHEVY ONLY... Nothin Else ! |
12-16-2010, 09:10 PM | #3 | |
I am close to just making this rig a "panel wagon". If so you can have the trims and glass. A gift on this site does not break any cardinal "jackass" rules for parts swaping. Does it? I need the double sloted steel frames for ALL FOUR windows. Plus the felts and rubbers that seal the frames and glass. I have not found any supplier that makes anything aftermarket for the carry-alls. |
12-16-2010, 09:34 PM | #4 |
Can anyone put in their 2 cents worth on installing 4 pieces of tinted 1 piece glass?
12-16-2010, 09:50 PM | #5 |
you can get the rubber i think from www.steelerubber.com/
you can put the one piece glass in without the sliders ron |
12-16-2010, 10:10 PM | #6 | |
12-16-2010, 10:38 PM | #7 | |
http://maps.google.com/maps?q=sidney...ed=0CB0Q8gEwAA |
12-16-2010, 10:40 PM | #8 | |
actually i am on an island in the pacific. about 80 mi north of Seattle wa.. I get to look at the san juan is. evryday. by the way I have a chesapeake laying on the floor beside me By rondavid at 2009-09-08 |
12-16-2010, 11:58 PM | #9 |
I am in the process of converting my sliders to fixed window. the overlapping sliders is a very poor design for my climate. it is a spendy affair to do either. fixed window rubber is about $170 a pair from steele. I had two fixed windows in my parts truck and had two more cut. Do not buy the rubber American Classic sells. I tried to cheap out and use it a about $16 a window. it is just a universal rubber that has to be cut to length. and it almost fits. almost. so a broken window later making it three custom cut pieces. has added another hundred bucks to the price of the next rubbers. I had to silicone the slider frames back in to get on the road since this is the womans daily driver. really looking foward to spending a day cutting them back out. my factory fixed windows measured 1/8" smaller all the way around than recess in the body when centered in the opening. thats what I used to to make the template for my front windows.
12-17-2010, 12:09 AM | #10 | |
chevy only
12-17-2010, 05:51 AM | #11 |
[QUOTE=padresag;4354473]do you know where Canada is?
actually i am on an island in the pacific. about 80 mi north of Seattle wa.. I get to look at the san juan is. evryday. by the way I have a chesapeake laying on the floor beside me COOL DOG! "Gulffishin" left a goggle map link to Sidney. You are long way away! looks like good fishing around you. I live to FISH! The Striped Bass (rock fish) bite is on real good right now in the Chesapeake Bay. |
12-17-2010, 06:09 AM | #12 |
Sorry man! That trim came off in a violent way! those trim holes where the reason this hole truck rusted out so bad and had to go. I stumbled onto this 66 and traded a TH-400 for it. Im into this build for less than a grand at this point and must keep it on the cheap side. SO, by just reading a few post here, I am going to weld and fiberglass the sheet metal in. A Panel Wagon in search of big Red Drum!
12-17-2010, 06:16 AM | #13 | |
12-17-2010, 03:53 PM | #14 |
65 suburban vortec 5.3 bagged
i pmed you!!
12-18-2010, 12:22 PM | #15 |
Resistance is Futile
I converted my 'burb to solid windows and ditched the sliders. I used 4 standard rubber seals to set the glass. The front windows are not the same shape as the rear, and it's slightly difficult to get the correct profile. Once past that obstacle you can install them like any piece of flat glass. Wrap the glass with the rubber and tape it on. I cut the corner at roughly 22.5* each so they meet at an angle of roughly 45*. Use a rope to load the channel and then lube it with silicon or Windex.
The factory used small rubber tabs to jack up the window into the correct position; I used left over pieces of the rubber gasket to do the same job. Its as difficult or easy as any glass install depending on your experience.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
12-18-2010, 12:29 PM | #16 |
I redid all of my sliders, my truck came with 4 sets and it was a pain. I ordered a kit from Brothers and it was junk, they sent a long straight piece of rubber that they expected you to miter at the corners. I basically threw the rubbers away and ordered another set from Steele and they fit. Like RustyRod, it too ended up costing me twice what it should have, must be an Oregon thing I guess.
Drumwagon, why dont you just remove the outer center support and get a 1 piece window cut, I have seen it done and it works well because you can retain the window rubber seal. Last edited by LT1 Burb; 12-18-2010 at 12:31 PM. |
12-18-2010, 11:02 PM | #17 | |
12-18-2010, 11:24 PM | #18 |
i have been thinkn about makin mine a flush fit like the new vehicals anybody try it or seen others
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
12-19-2010, 05:44 AM | #19 | |
12-19-2010, 09:26 AM | #20 | |
Anybody considering this option should take the time to get the glass tempered as the laminate will crack very easily with any pressure on the edges; or use original glass.
12-19-2010, 11:57 AM | #21 | |
chevy only
12-19-2010, 11:59 AM | #22 |
looks good but sombody butched the w/seals up so im gona hav to do over anyway but i was thinkn about the flush fit that is clean as u can get would hav to build the flanges out to make it work out any body done that ?
12-19-2010, 12:17 PM | #23 |
Yes, you leave the inner support in there but cut it to where the outer support does not interfere with the glass. I saw one at a car show done like this but I can't really remember exactly how it was done.It had a long tinted black window and it looked good.
12-19-2010, 12:31 PM | #24 |
i dont wana mess with that center post that would b abig piece of glass
12-19-2010, 06:07 PM | #25 |
I'm thinking about this ,but probably will not in the end. Even if you double the width of the pinch weld flange when the glass is set in it flushes out with the outer body. It just doesn't look right to me. If I do it I will relocate the flange 1/4" inboard. I did not want to spend the time to do this in the winter. but could have in the time I wasted on the rubber. I thought about installing them from the inside with the urethane. this would be easy just widen the flange 1/2" and the depth would look right. but then you would need a wide trim on the outside. that would not be worth the hassle. thats why modern cars have the 1" black band around the windows. to cover the glue .
Thread Tools | |
Display Modes | |
