Old 12-20-2010, 12:25 PM   #1
wiskydelta
wiskydelta's Avatar
Question about rust on a 65?
I'm familiar with the 67 -72 trucks but I'm thinking about buying a 65 Chevy, the guy has one that was redone quite a awhile ago but still looks decent, I can see some rust spots starting to boil up under the paint in the lower front fender and behind the cab. My question is where should I be looking hard to see if it's a basket case with paint?
Thanks in Advance
wiskydelta is offline   Reply With Quote
Old 12-20-2010, 12:39 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Question about rust on a 65?
This the post I suggest potential buyers take a look at:
http://www.stovebolt.com/techtips/bu...uide_60_66.htm
Old 12-20-2010, 04:07 PM   #3
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
The lower front fenders and rear cab corner is common, Mine had only the fenders that had been patched early on rest of the truck was rust free.. Gotta love the dry heat out here. Take a look at these pics of the fenders the make patch panels but the support can be a pain to deal with if it is bad shape.
GMR-PERFORMANCE is offline   Reply With Quote
Old 12-20-2010, 04:39 PM   #4
Big Fenders
Look in the windshield eye brow area...above in the gutter area and below the gutter...also leading edge of the hood..
Bob
Big Fenders is offline   Reply With Quote
Old 12-21-2010, 11:13 PM   #5
iiizman
iiizman's Avatar
Thats the deal breaker for me, I always check the drip rail and around the windshield. I never could fix that and make it look right. I know other guys that can, but seems like it always came back.
Bad Decisions usually make for Good Stories.
iiizman is offline   Reply With Quote
Old 12-22-2010, 12:29 PM   #6
dracko
dracko's Avatar
Should there be a layer of seam sealer in the drip rail on 60-66 trucks? I was reading in the 67-72 board about using sealer in that drip rail, but haven't heard much about it on this board. Drip rail of my truck isn't rusty at all, but also doesn't have any sealer in it.
dracko is offline   Reply With Quote
Old 12-22-2010, 12:41 PM   #7
wiskydelta
wiskydelta's Avatar
Thanks for the tips, I'm going to either pick it up tomorrow or walk away from it.
Old 12-22-2010, 09:37 PM   #8
Big Fenders
Definately...I used a wire wheel to grind out the old and then layed down the seam sealer .
Bob
Old 12-23-2010, 01:13 AM   #9
tapeworm
fan of "Butters" Stotch
tapeworm's Avatar
When you add new sealer, use some of the good catalyzed from 3M
I like the 08308
http://solutions.3m.com/wps/portal/3...gl7S9CZ5Q1J6bl
Works well, but you need a special gun to apply
64 shortbox fleetside
replacing rusty junk with more junk, and one day to become a real truck again
tapeworm is offline   Reply With Quote
Old 12-23-2010, 01:17 AM   #10
tapeworm
tapeworm's Avatar
Good luck!
Look everywhere
rockers, cab corners, fender and door lips, inner fenders, floor, kick panels, around the windsheild (inside & out) drip rails
These trucks rust everywhere!
It's not the end of the world if you have to patch a little, but may be some bargaining power
Old 12-23-2010, 01:25 AM   #11
dracko
dracko's Avatar
Thanks Bob and Tapeworm for the info. I'll be getting on that right away.
Thread Tools
Display Modes
