12-21-2010, 08:03 PM | #1 |
Crossmember ???
I have a 67 2wd C10 and it already had 5 lug disc brakes when I got it but I didn't notice until last night that they had swapped the control arms , steering linkage and possibly the crossmember too . The question is what is the difference between the stock 67 crossmember and the 73-87 ? Was the stock unit bolted in or riveted in ? Mine is bolted right now . Is there a visual difference ?
Demonspeed13 |
12-21-2010, 09:27 PM | #2 | |
Re: Crossmember ???
Some guys might swap the entire thing as a unit if the parts were fresh. Others might swap just the parts & re-use their existing x-member if rebuilding it all anyway. About the only visual clue would be the motor mount towers are different for the 73-87's & the lower a-arm u-bolt diameter increased to 9/16".
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-21-2010 at 09:28 PM. |
Thread Tools | |
Display Modes | |
