Old 01-29-2002, 12:15 PM   #1
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Talking Electric fan install in progess.
Here is pic of my setup.
[imghttp://home.mindspring.com/~gchemist/fans.jpg[/img]
It's an aluminum four core radiator with two 14" fans. I'm using a 454 radiator top mount bracket so the installation looks stock. Should look nice once it's installed.
Gerardo
1983 Custom Truck
TX Plates: "BAD BOW"
http://www.geocities.com/abetterchemist/
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 01-29-2002, 12:39 PM   #2
bigblock73
yeller
bigblock73's Avatar
Post
bigblock73 is offline   Reply With Quote
Old 01-29-2002, 06:56 PM   #3
gchemist
gchemist's Avatar
Post
Opps, Thanks bigblock73
Old 01-30-2002, 07:58 AM   #4
bigblock73
yeller
bigblock73's Avatar
Post
No problem! Your fan install is lookin sweet, what kind of fans are those? Other than maybe a little added horsepower, what is the reason you are converting to these? I have thought about doing a similar swap but the cost has always pushed me away. I like the clean look you get and HP is always welcome but does a cluth fan really make THAT big of a difference? Just wondering what you think.
Old 01-30-2002, 11:47 AM   #5
low 84
low 84's Avatar
Red face
I agree! That install is going to look clean! Where did you get the set up? How much? I would eventually like to do something similar on my 84.
'84 1\2 ton swb, 350 5\7 drop
just sold '64 1\2 ton
4\4 drop with built 350 (my toy)
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 01-31-2002, 07:41 AM   #6
gchemist
gchemist's Avatar
Talking
Thanks for the compliments fellas. Here is the breakdown on my setup.
$165.00 454 four core aluminum center with plastic ends radiator. I'm lucky to have found this one. A full aluminum radiator costs over $300.00. The price I paid for this aluminum core radiator is cheaper than a new copper replacement.
$45.00 per 14" fan from a company in Dallas, TX. They are actually a steal on www.ebay.com Guys usually sells them for $65 but since I wanted two so he cut me deal. The fans are actually GM factory type fans you find on some new Tahos and Yukons.
$59.99 www.painlesswiring.com block thermostat setup.
$19.99 454 radiator boltup bracket from www.cheyennepickup.com
$4.99X4 for the plastic top and bottom supports
$19.99 for the adjustable fan boltup legs.
Total=$374.78
You can cut some of the cost by using a different control switch, find some used 454 1 or 3/4 ton parts. Just don't skimp out on the fans.
I don't expect the fans to actually ever come on except for the summer time. A high flow water pump with the big radiator should do a very nice job cooling the engine. I will also be adding some Water Wetter to the system. From what hotrodders tell me, it will lower the engine operation temperature. The 305 will never get hot but with a planned 400+ HP 350 I want to plan ahead. The look will almost be factory since I will be using a factory radiator support bracket. Another reason I want to remove the fan is to clean up the engine bay. I will be running a serpentine belt setup from a 88+ truck. I've been looking for a 94+ serpentine belt setup without the smog pump option. My brother has one on his 94 and I like the look for my truck. I may resort to the dealer if I can't find a serpentine system. All the systems on ebay have the smog pump option. I don't need the smog pump option on my '83. Probably the last item for the converions is gas milage. I like to drive mine on long trips some which are 16 hour round trips. I'm getting close to 17 MPG and I would like to keep it that way when I drop in the 350.
I'll post a web page once the installation is complete.
[This message has been edited by gchemist (edited 01-31-2002).]
Old 02-26-2002, 03:43 PM   #7
Frank_Zeller
Frank_Zeller's Avatar
Post
gchemist, where did you purchase the rad from?
69 SWB C/10 3-6 drop with air lifts bags in the rear springs. 305 TH350 daily driver
69 Firebird Convert 455 4 spd
Austin-Texas
Web Page
69 SWB C/10 5-6 drop 700R4
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Old 02-26-2002, 08:47 PM   #8
gchemist
gchemist's Avatar
Post
Frank,
I bought it from a local boneyard. Boneyard had originally ordered for someone who never back to get it. It was sold to me really cheap or at cost. It's from a company out east. Not sure where though. I can find if you want to order one. Just let me know. The box I have has the darn shipping label right over the company name and address. Due to weather and other project I have yet to install the setup. Hopefully this weekend or next!! I'll post pics when I'm done.
Gerardo
1983 Custom Truck
Thread Tools
Display Modes
