12-22-2010, 01:52 PM | #1 |
Retired Air Force Veteran
Power Steering Pump Needs A Bath - Any Suggestions?
I took the Power Steering pump off to replace the rubber lines and this thing is in need of a bath real bad. I'm sure a degreaser of some kind is going to be the answer. Other than plugging the holes, should there be any other things I need to watch out for? What have you done? Any Suggestions?
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
12-22-2010, 02:14 PM | #2 |
Old member
Re: Power Steering Pump Needs A Bath - Any Suggestions?
Don't get any water in it. if you do make sure you dry it very good before using it. Mositure is the worst thing on a power steering pump.
Make sure it's pumping. I would take it and have it cleaned and tested at a hydrolic shop.
12-22-2010, 02:34 PM | #3 |
Thanks Andy
12-22-2010, 03:19 PM | #4 |
i'd use kerosene and a stiffbush to clean it up
12-22-2010, 04:14 PM | #5 |
I think it's CPP has new PS pumps on sale for a X-Mas special $39 plus shipping. At that price you could do that, borrow a pulley puller from one of the chain stores and swap out your clean brackets.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
12-22-2010, 04:28 PM | #6 |
I think those are brackets for $39.
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
12-22-2010, 10:49 PM | #7 |
Thanks for the info guys
12-23-2010, 05:51 AM | #8 |
That is for just the reservoir at CPP. You still have to use your pump.
12-23-2010, 07:49 AM | #9 |
Watch out for your cornhole !
You can get a complete reseal kit for your pump from the parts store for about 10 dollars. It's a very easy project to reseal one. This is one I did for Scoti and powdercoated all the parts during the job...
Remove the old front seal with a drywall screw... Install new seal... All reassembled with new seals on reservoir and fittings...
12-23-2010, 08:25 AM | #10 | |
12-23-2010, 01:39 PM | #11 | |
I've been so busy building hay trailers that I haven't been doing any powdercoating lately. I'm gonna be covered up until the winter is over and folks quit buying hay before I can do anymore.
Thread Tools | |
Display Modes | |
