Old 12-26-2010, 09:12 PM   #1
teeitup
Just like to part out trucks!!
teeitup's Avatar
trouble getting steering wheel off
any help is appreciated, I have a puller on it but the wheel won't pop off. I sprayed a little PB Blaster on it and am letting sit over night. I've had tough one before but they usually pop off. Any other ideas? Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 12-26-2010, 09:20 PM   #2
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Re: trouble getting steering wheel off
Randy,
Use a brass punch and a BFH to hit the top of the shaft while pulling up on the steering wheel. It helps to have 2 people to do this.
Don't forget to remove the nut holding the wheel on!!
Good luck!
low'n slow is offline   Reply With Quote
Old 12-26-2010, 10:13 PM   #3
JDL
JDL's Avatar
brass or led Hamer with the puller tight
72 Chevy short step side with 454 air and tilt.
72 nova project car
63 chevy II drag car
Agency Iowa
JDL is offline   Reply With Quote
Old 12-26-2010, 10:16 PM   #4
CUSHE63
CUSHE63's Avatar
Did you take the nut off ? I didn't want to sound like a d*ck.. but you never know. Ours came right off last week.. no problem.
CUSHE63 is offline   Reply With Quote
Old 12-26-2010, 10:17 PM   #5
pat 70/71
pat 70/71's Avatar
Originally Posted by low'n slow View Post
Randy,
Good luck!
x2, sounds real bad but I had a friend (not me) who was going pull his steering wheel. he removed the nut and just pulled real hard and off it came. and into his face went the wheel and chipped one of his front teeth! funny thing was I was on my way over with my puller!! so be careful and have a friend help. cheers, Pat
pat 70/71 is offline   Reply With Quote
Old 12-26-2010, 10:38 PM   #6
teeitup
teeitup's Avatar
Nut is off, 2 bolt puller with big bolt on shaft, 3 total, even drilled a bit on end of shaft to make sure puller is pulling straight. I've cranked the big bolt as hard as I can. Column is out of truck. I've taken 100's off but this one is not wanting to come. Thanks Randy
1980 chevy swb 4x4
Old 12-26-2010, 10:47 PM   #7
pat 70/71
pat 70/71's Avatar
Might want to think about putting the column back in the truck. maybe make it easier? last resort, cut it off? sorry! Pat
Old 12-26-2010, 11:17 PM   #8
chipflyer
chipflyer's Avatar
Randy,
with that puller cranked down tight, take a heavy hammer and give the puller bolt a good whack, it should pop right off with just a hit or 2.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 12-26-2010, 11:45 PM   #9
teeitup
teeitup's Avatar
Pat, I was wanting to save the column for my other truck may have to go another route now
Jeff, I beat on it quite a bit, its really frustrating me
Thanks Randy
1980 chevy swb 4x4
Old 12-26-2010, 11:55 PM   #10
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
You may be able to carefully heat it a bit with a torch....works great on old manifolds. WHY NOT ON A SPLINED STEERING SHAFT
Just an idea.
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 12-27-2010, 12:27 AM   #11
Boog
laying low
Boog's Avatar
Randy with the wheel still holding on strong after you using a puller and whacking it good with the hammer it's going to take a more serious approach. You've been nice to it up to now.
A bit of heat around the center while the puller is tight may help. Past that I'm thinking sawzall or grinder. Some relief cuts maybe. Are you trying to save the column or the wheel?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 12-27-2010, 12:48 AM   #12
mcbassin
Still Learning
mcbassin's Avatar
I was thinking heat too....
mcbassin is offline   Reply With Quote
Old 12-27-2010, 05:53 AM   #13
cdowns
cdowns's Avatar
Originally Posted by chipflyer View Post
Randy,
Jeff
this is the way all pullers are designed to b used// the shock is what is designed to loosen // excess cranking on the cenbter bolt is the leading cause of breaking a perfectly good tool
Old 12-27-2010, 09:18 AM   #14
teeitup
teeitup's Avatar
yes trying to save both, especially the column. I may try heat tonight, Thanks Randy
1980 chevy swb 4x4
Old 12-27-2010, 09:21 AM   #15
hot trux
'85 Stepside
hot trux's Avatar
if you have access to an air chisel, it always works for me. the vibration lets the penetrate work its way down...carefully though
hot trux is offline   Reply With Quote
Old 12-27-2010, 09:35 AM   #16
If you are having a hard time any one of us would,too. I wonder if the wheel wasn't forced on with the spline misaligned. In that case it may not be savable. Kinda hard to heat with the steering wheel plastic right there. Hey,why not sell the wheel and column as a unit? "Will not separate"
Old 12-27-2010, 10:07 AM   #17
chipflyer
chipflyer's Avatar
Sounds like you have a tough one Randy, give the PB Blaster little time to soak in, if its just rust it will do wonders. Rattle the puller with your air impact, whack the puller with a heavy hammer, rattle, whack, rattle, whack.
Good luck
Old 12-27-2010, 10:41 AM   #18
409impala1
use an air impact with a socket on low setting and let it hammer away, then up the setting and continue, whack the center pulling stud in between the impact tries.
409impala1 is offline   Reply With Quote
Old 12-27-2010, 09:39 PM   #19
teeitup
teeitup's Avatar
Never had much time to mess with it tonight, but I put some PB blaster on it.
1980 chevy swb 4x4
Old 12-27-2010, 09:51 PM   #20
too much stuff
Roadtrip!
too much stuff's Avatar
Is this going to be like the safe thread on general discussion? Is It Off Yet? (IIOY)
Good luck...
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 12-27-2010, 09:53 PM   #21
teeitup
teeitup's Avatar
I know what yrou saying Eric, what is strange the rest of the truck parted out real easy, bolts came off easy. I was wanting this column for the eagle truck, BUT who knows if it will ever come off. I hauled another truck home late last week and been trying to part it out while the weather holds. Hard to get much done in 1 1/2 hours after work.
1980 chevy swb 4x4
Old 12-27-2010, 10:36 PM   #22
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
I i o y?
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
Old 12-31-2010, 10:54 PM   #23
low'n slow
low'n slow's Avatar
Well??? We want to know if you got it off without chipping your tooth or getting a fat lip.
Old 12-31-2010, 11:25 PM   #24
LockDoc
The Older Generation
LockDoc's Avatar
I always leave the nut on even with the top of the shaft. That way it can't pop off and hit you in the face. It also keeps the top of the shaft from mushrooming out...
LockDoc
Leon
Old 01-01-2011, 09:14 AM   #25
chipflyer
chipflyer's Avatar
I was over there a couple days ago and it was not off then. Randy has the right puller, a big heavy hammer and plenty of penetrating oil and it still won't come off. Never seen anything like it, it is either forced on misaligned as Tim said or it has been put back on with red locktite. He was going to give it a little heat and try it again but not sure where he is at with the project. He does have the nut on even with the top of the shaft as you describe Leon. It is a stuck mother freckle!!!
Jeff
Thread Tools
Display Modes
