12-29-2010, 05:56 PM | #1 |
drag racing rear suspension
I'm new here, I really like to see I'm not the only one racing there big hunk of steel. My question is what type of rear suspension set ups are you guys running. I have a 71 C10 LWB/455 Buick bored and stroked to a 472 CID 3.73 gears. I can stomp it from forty and blow the tires off and from a dead stop use you can guess what happens from there.
Thanks Awsume Site |
12-29-2010, 06:19 PM | #2 |
Re: drag racing rear suspension
stock rear trailing arms ,anti-roll bar, and some use coilover shocks, basic stock rear setup. slicks is the first thing i would do 28x10.5 with your set up,and lose the front sway bar, this just gets things started for you, the track is the only place you can start the tuning process. vince
72 SUPER10 |
12-29-2010, 07:56 PM | #3 |
Registered Truck Offender
Ditto, street tires are never gonna stick with that kind of torque. Even the Drag radials and slicks will have a hard time hooking on the street.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
12-30-2010, 01:21 AM | #4 |
It's Better With Nitro
Kudos for running a Buick...as you can see from my signature, I'm a little partial to the BOPs (Buick, Olds and Pontiacs). As the others mentioned, going to a slick will help at the track. You can probably get away with investing in a set of adjustable rear drag shocks. And, if you can, try making small adjustments to the pinion angle. Start by going down by one degree increments to see if you are able to reduce your 60-foot times.
12-30-2010, 09:24 AM | #5 |
What do you guys think about the tube style trailing arms and cross members offered by the aftermarket, are they worth the money or just weld up the existing ones.
Thanks |
12-30-2010, 11:39 AM | #6 |
I welded up my existing ones then braced them top and bottom with 1/8x 1 1/2 flat bar,installed new bushings in the front of the trailing arms and use Rancho adjustable shocks in the back, my best 60 is 1.64 but i am still tuning.Save your money on the tube style ones and buy a good set of slicks
12-30-2010, 03:03 PM | #7 |
I use the stock trailing arms with coil-overs and an anti-roll bar. I did not use stock bushings though. I use a mon-ball from Stock Car Products if I am not mistaken. Had to modify the opening in te trailing arm, and weld the mon-ball housing in the arm. 1.34 60' times for mine. Paul
12-31-2010, 09:59 AM | #8 |
Thanks for all of the great input, studied alot of performance catologs last night. Wife asked what I was up to, she hates my truck which makes it that much better.
01-01-2011, 04:21 PM | #9 |
lmao !
NHRA Super Street 469C It only runs 10.90 at 156 mph |
01-02-2011, 10:58 AM | #10 |
I'm glad i'm not the only one.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
03-15-2011, 09:05 PM | #11 | |
Why lose the front sway bar? What does that do for the truck? |
03-15-2011, 09:40 PM | #12 |
It allows the truck to transfer weight better.
03-15-2011, 10:49 PM | #13 |
Ah I see. So if you take it out, do you have to add anything to the truck? Or can you just take it out and be done?
03-16-2011, 07:30 AM | #14 |
If you don't drive it on the street much just take it off. If you drive it primarily on the street just unhook one side from the lower control arm when you go to the track.
03-16-2011, 06:54 PM | #15 | |
"Where were you in '62?"
http://www.competitionengineering.co...s/chassis2.asp
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 03-23-2011 at 09:36 AM. |
03-16-2011, 09:32 PM | #16 | |
Yeah it's just a strip truck. Will Not be driven on the street. Is it just 2 bolts to get it off or what? |
03-16-2011, 10:26 PM | #17 |
4 bolts hold the bar to the frame then 2 bolts or links to the lower control arms.
03-18-2011, 12:00 PM | #18 |
Chris 1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas 7.02 @ 95.8, 1.45 60' 1965 Chevy C10 LWB, 355 sbc, TH350, daily driver |
03-21-2011, 12:29 PM | #19 |
Boosted Member
Tires are first and foremost, as the stock suspension is pretty darn good as it sits. I used to be able to light my 295/50/15 Radial TAs on the street at 60mph+
Let me just say that Mickey Thomson drag radials are a gift from the heavens. My trailing arms are reinforced with plate steel, and the rubber bushings are replaced with derlin bushings. My truck dead hooks at the track on 275/60/15 M/T DRs.....on air ride. Good luck and nice work representing those of us with flying bricks
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! Last edited by Wasted Income; 03-21-2011 at 12:29 PM. |
Thread Tools | |
Display Modes | |
