Old 12-29-2010, 07:17 PM   #1
-dylan-(OO==|==OO)
I dont drive fast,, I fly low!
-dylan-(OO==|==OO)'s Avatar
trailing arm questions?????
i have a 67 gmc with leafs in the back but i am considering switching to coils.... will the trailing arms bolt straight on to my frame???
____________
/_______\
(OO==||==OO)
67 GMC CUSTOM,72 GMC...65 chevelle...65 fastback mustang...75 VEGA...90 lx mustang...90 supercoupe...90 jeep wrangler...04 mach 1 mustang...06 toyota tacoma...08 nissan altima
-dylan-(OO==|==OO) is offline   Reply With Quote
Old 12-29-2010, 07:31 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: trailing arm questions?????
Crawl under it and see if it has a trailing arm crossmember, if it does all you'll need is a rear axle, panhad bar, panhard bar mount to frame a coilspring rear end.
John
1999 Toyota Tacoma 4x4
Old 12-29-2010, 08:04 PM   #3
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
there's a bit more to it then that. There are also shock mount changes. I've changed over my '68 GMC from leafs to coils and got everything off my donor frame except for the panhard bar frame mount. IIRC...you'll need the coil spring shock mount crossmember with shock mounts, the reinforcement plates that go under it, the lower shock mount brackets that mount to the trailing arms at the axle, a panhard bar with frame mount and the mount for the rear axle (numerous choices)...plus the trailing arms and their mounts to the center crossmember.
Oh. And you'll need to have everything you like to use to cut off about a couple dozen rivets......per frame...both yours and the donors unless you purchase the parts ready to install.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 12-29-2010, 08:14 PM   #4
-dylan-(OO==|==OO)
i am wanting to convert mine but wud like to leave the factory dana 60 (posi) in it...??/ have any ideas to what i can do?
____________
/_______\
(OO==||==OO)
Old 12-29-2010, 11:03 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
oldblue1968chevy- Please do not solicit sales in the discussion forum. Your offers will get this post closed, and infractions against your account.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-29-2010, 11:11 PM   #6
eagleuh1
eagleuh1's Avatar
Do a setup with homemade trailing arms with the panhard bar attached to the back of the trailing arm. Theres a member here that did it with a Lincoln M4 rear and coilovers. Real sharp. Thats for Dylan. Link below.
http://67-72chevytrucks.com/vboard/s...d.php?t=414961
eagleuh1 is offline   Reply With Quote
Old 12-29-2010, 11:21 PM   #7
68GMCCustom
You can keep your Dana 60...just go with the longer aftermarket style panhard rod that attaches to the axle at the axle pad/ubolt. Its a better seup anyway!
Kurt -
Old 12-29-2010, 11:26 PM   #8
oldblue1968chevy
My bad, I didnt know. I saw he was closeby and thought Id say something. Best way to go about this would be PM? Anyway, back to the topic.
Anyway, What kind of fab skills do you have (could you weld the saddles on the axle, I know I couldnt otherwise I wouldve done it already)..
John
Old 12-29-2010, 11:57 PM   #9
-dylan-(OO==|==OO)
so i will need to get the axle brackets and weld them onto the rearend and get the trailing arms and go from there??
____________
/_______\
(OO==||==OO)
Old 12-30-2010, 12:41 AM   #10
70cst
70cst's Avatar
All sales needs to be in the open forum to my understanding.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 12-30-2010, 01:05 AM   #11
oldblue1968chevy
So...Im confused? How should I have went about it to him? No Pms or posting here?...
Yeah, to keep your current rearend, you'd have to weld some perches onto your existing axle (center it, pinon angle right, etc). Others would be more knowledgeable about this than myself (no experience, just telling you what I think I know )
John
Old 12-30-2010, 01:09 AM   #12
Mike Bradbury
Mike Bradbury's Avatar
Are you sure that your D60 is posi? Mine was not.
I did the conversion Eagleuh1 referred to and it is a lot of work unless you have a donor complete rear setup. Welding brackets to your 60 will require straightening after welding. It induces a lot of stress to one side of the axle and the distortion will lead to premature failure of bearings and seals if it is not straightened. Nate at Porterbuilt makes a complete setup as long as you have an axle to bolt to.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 12-30-2010, 08:09 AM   #13
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
dylan, I did the swap from leafs to trailing arms on my 69' GMC. It was a weekend project once I had all the parts (pretty simple, just my son and I)
I bought the trailing arms from a swap meet.
I bought the following parts from board members in the parts section. I posted a WTB:
Cross Member Brackets
Frame Bracket (D/S) for Super Track Bar
From Early Classic Enterprise (ECE)
Super Track Bar (Used this cause I installed 6 inch lowering springs in the rear. P.S. I DID NOT have to C-Notch it)
Axle Saddle Brackets
Shock Relocator Kit
GMC Pauls
I also put 3 inch lowering springs in the front I got from a friend
I used all grade 8 hardware to install the frame and cross member brackets
Although, I purchased the Axle Saddle Brackets, I never used them (sold them to a board member) I ended up getting a 72' 5 lug rear end and 5 lug disks from the same truck
Here's how it sits today:
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 12-30-2010, 10:28 AM   #14
-dylan-(OO==|==OO)
o ok thx guys... now just need to find the parts to do all of this with.....
yea my dana is posi, 3:54 posi
____________
/_______\
(OO==||==OO)
Old 12-30-2010, 10:36 AM   #15
myoldchevytruck
I bought my frame and cross member brackets from a board member in Georgia. His name is Tim (board name "Uncle") Also try Randy "teeitup" he's in Kansas. Good Luck.
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 12-30-2010, 02:15 PM   #16
-dylan-(OO==|==OO)
after looking it over and all the labor that im going to have to do welding all the brackets to my dana i think im just going to find a coil frame and get all the parts including the rearend and swap them out and put the dana in the 65 chevelle....!
____________
/_______\
(OO==||==OO)
Old 12-31-2010, 12:15 PM   #17
Tim Christian
Tim Christian's Avatar
Why did you all swap? My 67 has leafs and I love em!!!!
Tim Christian is offline   Reply With Quote
Old 12-31-2010, 12:52 PM   #18
myoldchevytruck
Tim,
For the 3/6 drop I currently have and for the future of bagging it. Plus my 69' has a 68' front end, the tailgate says Chevy all of the emblems say Chevy so I ousted the GMC and made it a Chevy. BTW, great looking truck.
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 12-31-2010, 01:07 PM   #19
Mike Bradbury
There is nothing wrong with leafs, they are a tried and true form of suspension that work well and is very effective in its job. But there are some other aspects that trailing arms are a bit better choice. The leafs are heavy when considering unsprung weight, also axle wrap under high torque situations is a factor that trailing arms very simply eliminates while reducing the unsprung weight. I was converting from a C20 to a C10 and the huge leafs would have needed to be completely redone, besides the fact that I was changing my entire axle and wanted a bit more control than what my leafs could give.
Thread Tools
Display Modes
