Old 12-30-2010, 11:21 AM   #1
69gmc292
lowering rear end question
Hello,
I have done a spring over drop on my 69 gmc long bed over a year ago and i had a bad clunk when i would go from reverse to drive. After I jacked up the truck i noticed that the pinion was moving around in the housing. The rear end was not leaking and there was no metal bearing material in the gear oil. I was think about putting a new crush sleeve, input seal, and pinion nut on. I am thinking that this happened because of the new angle out the pinion after the drop. I am also running a drop carrier bearing too and my u joint angles are well with in spec of what I have read online. Have any one have had the same type of problem after they dropped there truck.
69gmc292 is offline   Reply With Quote
Old 12-30-2010, 11:30 AM   #2
cdowns
cdowns's Avatar
Re: lowering rear end question
only time i've seen that pinion problem was due to improper installation techique of the pinion// it needs a bunch of torque for the proper preload// alot of doityerselfers dont get the torque and preload right
Old 12-30-2010, 01:07 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I'd bet the old pinion nut just backed off. They are supposed to be self locking, but if it's ever been removed a time or two it's probably not holding much tension anymore.
Thread Tools
Display Modes
