Old 12-30-2010, 06:57 PM   #1
jakeblues652
jakeblues652's Avatar
weak manual 4 wheel drum brakes?
i was wondering how bad/good these are supposed to stop. my truck has 4 wheel manual brakes, and it dosent like to stop. at all. you literally need to stand on the brakes going down a hill and you still are flying by the time you reach the bottom.
i was thinking about adding a booster, but im thinking there must be a problem somewhere.
i am in the process of replacing the wheel cylinders, so we'll see how much of a difference that makes.
1967 K-10 4x4 with a 3" lift and 35" BFG mud terrains
Originally Posted by Dan in Pasadena View Post
Did you figure out how to fix it?...I mean with other than a BFH?!
want to see some slow progress on my truck? http://67-72chevytrucks.com/vboard/s...d.php?t=436560 <-click there
jakeblues652 is offline   Reply With Quote
Old 12-30-2010, 07:06 PM   #2
vectorit
What?
vectorit's Avatar
Re: weak manual 4 wheel drum brakes?
Mine were like that...
I rebuilt the entire brake system, and it stops much better now.
Booster, MC, all 4 WC's, shoes, all rubber lines, and new springs in each drum.
Though, nothing like disc brakes. They will stop my 68 K20 burb, with out me going through too much of a panic attack.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 12-30-2010, 07:35 PM   #3
Wrenchbender Ret
Some of the drum brake shoes we get now just don't seem to have any friction in them. Make sure everything is in good shape. If you havn't done anything to the wheel cyls lately they may be sticking. If a larger dia. cyl. is available that would help. You should put on a booster. I you need to change linings I have had good luck with Carquest.
Wrenchbender Ret is offline   Reply With Quote
Old 12-30-2010, 07:56 PM   #4
70 shorty
Where's my beer?
70 shorty's Avatar
That definitely sounds like something is wrong. I have 4 wheel manual drums on mine, and don't find them to be nearly the terrible brakes everyone makes them out to be. I certainly don't have to stand on them to get them to stop. I'm used to very good 4 wheel power discs on my Vette too.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam.
79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam.
'03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great
'08 Tahoe LTZ 4x4 155K
70 shorty is offline   Reply With Quote
Old 12-30-2010, 08:38 PM   #5
Shyguy
Junior Member
Shyguy's Avatar
If the brakes are in good condition they should stop your truck just fine. If you put new shoes on make sure you have the drums turned or get new ones. One of the problems with manual brakes is the adjusters get rusted and the self adjusters don't work.
Also make sure you clean and lub the adjusters.
Since most people are not use to manual brakes, adding a booster is a good idea. I don't have one on either of my trucks, but I am use to driving the old iron.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 12-30-2010, 08:46 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I've had them where the old front brake hoses completely plugs internally. The truck literally would not stop.
Old 12-30-2010, 09:17 PM   #7
jakeblues652
so since its apart, i plan on draining the system(the fronts at least) and then throwing my WC back in and bleed all around in hopes that i have good stopping power afterward.
Thread Tools
Display Modes
