Old 12-30-2010, 10:44 PM   #1
-dylan-(OO==|==OO)
I dont drive fast,, I fly low!
-dylan-(OO==|==OO)'s Avatar
crossmember ?s
i am wanting to change my leaf setup over to coils and am wondering if i can bolt the trailing arm brackets to my crossmember???
____________
/_______\
(OO==||==OO)
67 GMC CUSTOM,72 GMC...65 chevelle...65 fastback mustang...75 VEGA...90 lx mustang...90 supercoupe...90 jeep wrangler...04 mach 1 mustang...06 toyota tacoma...08 nissan altima
-dylan-(OO==|==OO) is offline   Reply With Quote
Old 12-30-2010, 11:00 PM   #2
dyrt
Re: crossmember ?s
what year is the truck? you should be able to get the brackets from the same year truck and bolt them right on. someone else will have to chime in since i don't have a leaf spring truck handy, but i believe you will also have to find a set of the plates that go on the next crossmember back where the coils sit against the frame as well as a stabilizer bar bracket.
Mike
dyrt is offline   Reply With Quote
Old 12-30-2010, 11:09 PM   #3
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: crossmember ?s
that looks like the same crossmember I have in my field (except mine has mounts for trailing arms on it)
John
1999 Toyota Tacoma 4x4
Old 12-31-2010, 09:44 AM   #4
lofly'a
lofly'a's Avatar
Re: crossmember ?s
yes you can, and the holes are already there in the trailing arm crossmember for the conversion, i did it to my 71 gmc last summer. if you are gonna make the swap get all the riveted on brackets past the trailing arm crossmember including the parking brake bracket as they are different from the leaf setup. you can use parts from any 67-72 trailing arm truck.
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline   Reply With Quote
Old 12-31-2010, 10:30 AM   #5
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Re: crossmember ?s
Attachment 674267
YES YOU CAN. I did this swap 2 years ago. I Have a set of Trailing Arms Brackets that will bolt right up to your cross member. I used (8) Grade 8 Bolts to install my brackets. If your interested in the brackets, PM me. How's $25 plus USPS Medium Flat Rate Shipping Cost of $10.60. So $35.60 Total
Thanks, Harry
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Thread Tools
Display Modes
