Old 01-02-2011, 02:16 PM   #1
cobra1966
Oil Pressure Line
Hello
Just to confirm. Does the oil line kit from Classic Parts complete the connection from the engine block to the gauge? I believe it does but not sure to order it up. One person told me to go electrical. I am trying to keep cluster original
Lewis
http://www.classicparts.com/1947-77-...ctinfo/24-781/
cobra1966 is offline   Reply With Quote
Old 01-02-2011, 02:19 PM   #2
bosco200
bosco200's Avatar
Re: Oil Pressure Line
Yes it goes straight from the block to the cluster.
bosco200 is offline   Reply With Quote
Old 01-02-2011, 02:24 PM   #3
cobra1966
Thanks for the help. I knew someone knew the right answer. My father and I are new to the 1972 Chevy Truck C-10. We are learning as we go. I am glad for this forum and Chevy Guru's
Lewis
Old 01-02-2011, 02:33 PM   #4
haysonj
haysonj's Avatar
Originally Posted by cobra1966 View Post
Hello
Lewis
You can buy that kit at any auto parts place just tell them you want the one with the copper not plastic line.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 01-02-2011, 02:48 PM   #5
cobra1966
Ok. I was thinking I have to order it up. I will look into AutoZone since thats where the old man likes to shop at. I should be able to find it there or else where like pepboys...
Lewis
Old 01-02-2011, 02:54 PM   #6
cobra1966
http://www.classicindustries.com/con...ch&keyword=oil pressure line&productSearchCatalogId=4&productYearId=118&sortOrder=1&sortBy=1&listAs=1&currentPage=1
The link shows 3. I have a 1979 Chevy 305. Which of the 2 should I order if I dont find a good one? I am thinking the small block in middle. Any suggestions?
Lewis
Old 01-02-2011, 02:57 PM   #7
bosco200
bosco200's Avatar
Yea just go to Auto Zone they should have it in stock thats where I got mine for my 72.
Old 01-02-2011, 02:57 PM   #8
planewhisperer
U.S. Army Green Beret Sniper
planewhisperer's Avatar
The original oil pressure line are hardlines. Installed on the rear part of the engine just on the left hand side of the distributor. I just replace my sons yesterday............
"YOU CAN RUN AND YOU CAN HIDE, BUT YOU WILL JUST DIE TIRED"
planewhisperer is offline   Reply With Quote
Old 01-02-2011, 03:01 PM   #9
Lee H
Lee H's Avatar
Pay careful attention to the fittings in the picture. They are special and not just any oil line kit will work. The oil gage will have the correct fitting built in. You will need to check the block fitting. If you try to use a generic oil line kit with ferrules you will ruin the gage fitting and it will leak.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 01-02-2011, 03:05 PM   #10
cobra1966
Thanks to everyone for the positive input.
Lewis
Thread Tools
Display Modes
