Old 01-02-2011, 07:58 PM   #1
slobberdogs
Brake bleeding trouble
alright what am i doing wrong? Removed calipers(drained) on front to replace front suspension and spindles. Put all back together and now can't get air out. I have probably pumped 12 oz per side through still air in lines. the mc cap is on snugged but not completely clamped. Is that letting air in?
slobberdogs is offline   Reply With Quote
Old 01-02-2011, 08:06 PM   #2
justincat
Re: Brake bleeding trouble
You might have to bleed the back wheels first. Start at the longest line, and work to the shortest. Make sure Your not leaking anywhere. I alway take the lid off of the mc, but im not sure if thats the right way or not.
justincat is offline   Reply With Quote
Old 01-02-2011, 08:09 PM   #3
cdowns
cdowns's Avatar
pin on prop valve must b clamped in center//good directions on proper bleeding of brakes in factory service manual
Old 01-02-2011, 08:59 PM   #4
slobberdogs
alright just noticed rr is leaking now probably the wheel cylinder. will the let air into front lines via prop valve
Thread Tools
Display Modes
