Old 01-02-2011, 09:35 PM   #1
brans72
Radiator clean up?
Ok not 100% sure it will work but gonna try it since was free. My buddy gave me a free 3 core raditor from his 72 truck. I wanna clean the paint off the pants and respray it. So far got a decent mount of paint off but wanna get tanks clean as possible and prep it correctly. So any tips for me guys I know tanks are bronze and wanna prep and paint correctly. Brandon
brans72 is offline   Reply With Quote
Old 01-02-2011, 09:59 PM   #2
Duncan and son
Re: Radiator clean up?
Best thing to do is take it to a radiator shop, have them vat it and run a pressure check to check for leaks and it will come out clean and all old paint gone. Tell them not to paint it because you can do it better than them. You do need it checked so you don't do all this and find it is no good.
Hope that helps Paul
You can shear a sheep every year, but you can only skin it once
The person dealing with facts is never at the mercy of the person dealing with theory
1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn
1975 Silverado 454 Crew cab camper special dually
Duncan and son is offline   Reply With Quote
Old 01-02-2011, 10:21 PM   #3
brans72
You know what they normally charge?
Old 01-02-2011, 10:23 PM   #4
Andy4639
Old member
Andy4639's Avatar
Lightbulb Re: Radiator clean up?
For the peace of mind it will be worth it. They can fix anything wrong with it and I bet less than $150.00.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-02-2011, 10:26 PM   #5
brans72
i can mock it up etc and pressure test my self for $150
Old 01-02-2011, 10:34 PM   #6
Andy4639
Old member
Andy4639's Avatar
Then go for it!
I wouldn't put a lot of time into making it pretty until I knew it was going to work!
Old 01-02-2011, 10:40 PM   #7
bigolddog
I bought a four core at a local pic and pull about a year ago. Took it to a shop here in town. they cleaned it, checked it, and repaired one small leak for like 30 bucks.
bigolddog is offline   Reply With Quote
Old 01-02-2011, 10:41 PM   #8
brans72
That is more like it Bigoledog!
Old 01-02-2011, 11:54 PM   #9
Duncan and son
If is just clean and check it should be $50-75
Old 01-03-2011, 12:41 AM   #10
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Radiator clean up?
As stated they could fix everything wrong with a radiator for less than $150.00.
Just depends on what they have to do.
The radiator is part of the life line of the truck and should have the best you can do to it to make the truck run as long as it can!
Thread Tools
Display Modes
