Door striker question...
When you close your door, does the mechanism click once or twice? I think it needs to click twice but I can't get mine to hit the second time? Anyone?
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
#2 | |
Bloo
depends on how i close it
![]() if i push it up slow, it does one click, then kinda push it harder and quick to get the second click, or if i close it like normal, one click
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
![]() Last edited by Blue_71; 03-11-2003 at 12:48 AM. |
If you look at the jaw thats on the door pillar there should be teeth there that would turn the wheel thingy on the door latch to make it click. I think I recall there being two teeth, therefore two clicks. Does your door line up nice the way it closes now?
its all about the +6 inches
2 clicks.
It lines up nicely. I have new rubber. I can get the first click and maybe half of the second click. I push like a son of a you know what and it goes no further. I've pulled the door hinges out all the way (at the front). The door just doesn't want to close that extra little bit.
#6 | |
Bloo
are you just pushing the door up or "slamming" it?
Just pushing
#8 | |
Bloo
as much as you mgith hate to, might try slamming it once... what i was talking about in my first reply, when i push i get 2 clicks, when i slam it just sounds like 1
You will have to adjust the striker plate on the jam. I had that trouble too, the new door rubber is quite thick, and I adjusted the hinges out to accommidate the door latch, but the only way it would work, the front of the door wasn't tight to the rubber, so I had to adjust the hinges back in and adjust the striker plate. My passenger door worked out great, but the drivers side still takes a good push to close it, couldn't adjust the striker plate out anymore than I did, it takes a little playin around, thats my 2 cents
Thread Tools | |
Display Modes | |
