Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-12-2011, 03:24 PM   #1
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
The 383 is dead
Long story short the builder robbed me , and use too long of a bolt in balancer wich in turn never got tight and cracked the snub, took it apart .. no steel crank, cast ,.no bushed rods, block was at 60 over not 30 so a huge pile of chit.
SO I have a 400 that I found virgin bore!!! Going 30 over CP pistons, H beam rods, steel crank all scat stuff there. New XR294HR cam, touching up the RHS 220 heads. Valve size is 2.055/ 1.600 , setting compression to 10.7. Should run very well. Killed the forward progess on the truck for the time though
So any one need a 4 bolt 60 over block SHould make a nice table
GMR-PERFORMANCE is offline   Reply With Quote
Old 01-12-2011, 04:19 PM   #2
heeroyue2002
fat old dude
heeroyue2002's Avatar
Re: The 383 is dead
did you have the builder refund?
1972 c-10 shortbed 350/400
build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157
1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216
Accepting part donations
heeroyue2002 is offline   Reply With Quote
Old 01-12-2011, 04:39 PM   #3
GMR-PERFORMANCE
Re: The 383 is dead
Builder is no longer around... he has done this to countless others as well... So at this point it is out of my pocket for the second time. I am doing this engine myself. I was too busy with my own shop at the time and had him do it. I dropped all the parts off to him , so where they went is any ones guess.
Nothing I can do, but the up side is the new engine is going to be a very nice build. I am going to dyno the new engine in the truck so I will know I have. I am doing this build very close to another that was tuned on a engine dyno. It made just shy of 560hp @6500. I have a bit more carb, larger valves , more compression, so we shall see
Old 01-12-2011, 07:18 PM   #4
Wild83C10
Wild83C10's Avatar
Re: The 383 is dead
The perfect example of why you should use a shop that has been recommended by others.
Sucks to hear you got ripped. Good Luck with the new motor.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 01-13-2011, 06:28 AM   #5
283nova
Re: The 383 is dead
.060 not that big a deal have seen many go .080 yes 350's no they didint run hot.
my 283 in my nova is .125 magged and checked out GOOD. stays at 160* all day long never hotter then 180 even at the dragstip
283nova is offline   Reply With Quote
Old 01-13-2011, 09:51 AM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: The 383 is dead
builder is no longer around like not in business, or like in dead moved etc?
Reason I ask, is that I'd come looking for my money..doesn't matter if he doesn't have a biz anymore...if you can find him, make him cough it up.
You say he's done this to others? If there are enough, you may be able to take him to small claims.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-13-2011, 12:34 PM   #7
GMR-PERFORMANCE
Re: The 383 is dead
Some blocks can be bored beyond that however you need to see how much core shift is in the block. Easy way is look at the cam boss. If the hole is centered you can go beyond however if it is not , then really not a good idea. Again it may be based on what you use the engine for and what power level you are at or going to be at.
In my opinion money spent on a strong lower end and block is the base ot all good engines. People build homes on the edges of cliffs some times it works other times the house falls off..
The builder is missing at this point.... what I know he may be dead as I am but a small fish money wise compared to several others. I know of one guy that lost 175K on a pair of dart based blown BB for a deep v race boat.
Old 01-13-2011, 01:03 PM   #8
Marv D
Registered Truck Offender
Marv D's Avatar
Re: The 383 is dead
Ditto, The sbc cylinder wall is thin enough. You start putting serious power to a virgin wall and you get enough flex compromise the cylinder. Boring and SBC more than +0.040 is never a part of anything I'd do. Not when virgin 4" bore blocks can be had for less than $100. Not worth the risk of building a $800 motor or a 2,3 or 8 thousand dollar motor in a questionable foundation.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 01-13-2011, 01:06 PM   #9
GMR-PERFORMANCE
Re: The 383 is dead
Marv check your Pm box. Thxs
Old 01-19-2012, 11:00 AM   #10
GMR-PERFORMANCE
Re: The 383 is dead
Hey Marv
the 407 will be done in 4 weeks!! Been slammed running the HD side gotta make money to buy the toys..LOL
Chnaged to the Howards version of the 294 cam and roller retro lifters. Other than that pretty much the same. CP pistons,.
Thread Tools
Display Modes
