01-18-2011, 05:58 PM | #1 |
C10 addict
15x8 rally wheels up front with drop spindles?
I've heard mixed opinions on whether 15x8 rallys will rub with a drop spindle. I have a set of 15x8 rally wheels and wanted to run 275/60's out back and 235/70's up front. The overall height of these tires are the same and I've seen this combo before and thought it looked good. Will I have any rubbing issues since the drop spindle moves each tire out 3/4"? The attached picture has this wheel and tire combination. I borrowed this picture from a fellow member
Would I be better off buying a set of 15x7's and running 215/70's up front? Pics of rally wheels with wheel/tire sizes and drop would be great! |
01-18-2011, 06:19 PM | #2 |
Fabricate till you "puke"
Re: 15x8 rally wheels up front with drop spindles?
I dont think a 2 1/2 " spindle drop will give you too much "trash" on tire rubbing....but are you dropping the spring also? I run a cut coil (1 full ring up front), & figure that to be about 2 1/2" drop. Along with that is a 1 1/2" body drop, & I opted for a set of 6 1/2" van ralleys up front. Fronts are 225/75, & the rears are 255/70, on an 8" ralley. I am sure some of the rest will "chime in" on what has worked for them crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
01-18-2011, 06:29 PM | #3 | |
C10 addict
01-18-2011, 06:45 PM | #4 |
Only the drop spindle will effect if the rim rubs on the lower control arm and lower ball joint, the spring drop will not. My 1974 with a 3" belltech drop spindle, rubs on the control arm with the steelie wheel that originally came on the truck, with modest trimming the rim cleared the ball joint.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
01-18-2011, 06:52 PM | #5 | |
C10 addict
I'm concerned with the inside edge of the tire contacting the rear of the wheel well or fender during tight turns. Last edited by mahanian; 01-18-2011 at 06:54 PM. |
01-18-2011, 07:02 PM | #6 |
Well, I've got a 2.5" spindle drop with a 1" spring drop in the front...with a 4" spring drop in the rear. I have 255/60 tires on 15" Ralleys all the way around and I have ZERO issues. When the weather improves, and I can get home early enough, I'll post a picture or two.
PS...I have a 70 CST S/S with 5 lugs around and the added weight of a BB.
John Paap Ole Greenie Hagerstown, MD My Mistress 70 CST Short/Step LS 5.3/4L65E New motor install Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=667773 |
01-18-2011, 07:11 PM | #7 | |
C10 addict
01-18-2011, 07:17 PM | #8 |
Redefining LowBudget
hey Greenie Thanx for wearing that funny suit...
next how did you do the rear swap to 5 lug now back on track....... Your not going to have any issues with the RIM hitting I'm bagged and can run till my LCA is against my X memeber with no issues...BUT the tire is going to be way to close I would try the 235/75 on a 7" rim..it gives a great stance and make your rear tire look a bit bigger..also be sure to check your clearance on the top off the inner fender, hood hindge and heater box
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
01-18-2011, 08:51 PM | #9 |
....If you go to Webshots , under Hotrodhorn , you will find a few old pics of the truck. It ran 275/60's rear/ 225/75s front at the time, & the rings were different. I am running late 80's-mid 90's trim rings on all 4 corners, with the same 3 bar spinners that you show on the short step posted(need to upgrade pics) as far as backspace, I dont think you will find much diff tween the 8" ralley vs the 6 1/2 " version, but I can measure a pair up tommorro if you need to know? crazyL
01-18-2011, 09:48 PM | #10 | |
Hottrucks...I found a good rear gear from a local yard and did a swap. I think it was out of a 78 C10. Wearing this suit is truely my pleasure. Although at times I experience difficulty wearing it, there are a very few professions as honorable. I have been wearing it now for about 25 years and it just gets better. As a servant, it gives me pleasure to be a bastion of freedom for this country and indeed the world.
01-18-2011, 10:12 PM | #11 |
I have 2.5 spindle 1"CPP coil 255 60 on 7" van rims. They did rub when I went to 2" drop coil. There are 3 diffirent rims 8 truck 7 truck and van and the 6.5 van you will need the van rims for the 4.5 drop.
Moser makes axels that fit in place of the stock 6 bolt. use 71 72 drums
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
01-19-2011, 02:24 AM | #12 | ||
C10 addict
01-19-2011, 11:46 PM | #13 |
I had to go to Van rallies in the front. This is a pic of My 8" rallies that rubbed with the ECE 4/6. I have the other two van rallies you can have if you want to spring for shipping. Let me know.
01-19-2011, 11:51 PM | #14 |
I will post a pic of the truck with the van rallies tomorrow. Huge difference and looks much better.
01-19-2011, 11:58 PM | #15 |
Grandpa in the rustmobile...
^Nice gesture those are hard to come by so i hear..
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
01-20-2011, 12:14 AM | #16 |
Just FYI, the van rallies I have are 6.5's.
01-20-2011, 03:25 AM | #17 |
C10 addict
What size tire were you running on the 8" rallys up front in that picture and what size tire are you running on the van rallys now? That is an awesome offer and I will take you up on it! Just let me know what shipping is to zip code 85224
01-20-2011, 08:19 AM | #18 |
This is informative,except people need to include where there's rubbing as well. I've read this and my concern is rubbing with 8" steelies on the lower control arm. It's hard to know who's had tire rub and who's had wheel rub. Also, be sure to mention tire size.
What I'd like to run is 8" steel oem-type (same dimensions as rallyes) with what they call a 4" drop,but it's 2.5" spindles and 1" springs.(I could never figure out why they call this a 4" drop)
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 01-20-2011 at 08:19 AM. |
01-20-2011, 08:58 AM | #19 |
Mine has 2.5 spindle and 1.5 spring. It ended up lower than I had hoped or expected!
Posted via Mobile Device |
01-20-2011, 05:18 PM | #20 |
special K the way I understand it is that the rim rubs the lca not the tire with that much drop most inner wheel wells are gone anyway ...
Also the way I understand it is that once you get into dropping a truck alot you run into issues and here they are in the order that they will hit wheel wells inner fender brace hood hindge heater box I'm stopping just short of the heater box with cupped LCA, bags, 2 1/2" drop spindles,8" rallies (control arm trimmed) wheel wells gone ( replaced with 13" wide trailer fender) trimmed inner fender support and the hood hindge cut and a new bolt added.... Now keep in mind this is with a 29" tall tire (235x75) and the stock X memeber will lay ON THE GROUND so I will install bump stops. there will be aprox 3/4 to 1 inchof wheel travel left ( upwards) this will keep my ride height low |
01-20-2011, 07:26 PM | #21 | |
Ok...As promised, I took a few pictures of Ole Greenie to give you all an idea of the drop I did to it. Specs are: 2.5" spindle drop 1" front spring drop 4" rear coil spring drop (this gives me about 1.5" to the rubber bump stops) BB 454 LS6 (SB weight may vary) I'd also like to point out that I have 255/60/15 on 15" Ralleys. Reds I believe had 275's on 8" Ralleys and were rubbing before he switched to the van wheels. Just a thought... I also installed a CPP front sway bar. From this: To this: http://im1.shutterfly.com/media/47a1...D720/ry%3D480/ Never mind the paint. She will be going into the paint shop in two weeks.
John Paap Ole Greenie Hagerstown, MD My Mistress 70 CST Short/Step LS 5.3/4L65E New motor install Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=667773 Last edited by Ole Greenie; 01-20-2011 at 08:20 PM. |
01-20-2011, 07:37 PM | #22 |
To be more clear they Did Not rub with the 2.5 spindle and 1 " coil. They did rub when I went to the 2" drop coils. they rubbed the outer top inside of the inner fender
01-20-2011, 07:45 PM | #23 |
Kid's Mechanic
Gentlemen , If you have something for sale it needs to be placed in the correct Classified forum . Thanks
01-20-2011, 08:13 PM | #24 |
I originally had 275/60's all the way around on 8's. Lots of rubbing on fender lip. I switched the front to 225/70 on 6.5's. No rub at all now. Not the best pic, but it was dark when I got home. I will try to get a better pic on Saturday of the whole truck. I was worried about the wide rear and skinny front look, but I am very pleased with the look until I can afford a set of coys and new tires.
01-20-2011, 08:43 PM | #25 |
67-72 parts collector,…
Ole Greenie,... I really like that stepside of yours!
Thread Tools | |
Display Modes | |
