Old 01-21-2011, 09:21 PM   #1
nachodog2
Hell yeah!!!
nachodog2's Avatar
1964 gmc
i posted some of these before but never did a build thread on it, so her it is so far.
Stock is good but custom is the sh*t!
nachodog2 is offline   Reply With Quote
Old 01-21-2011, 09:36 PM   #2
nachodog2
Hell yeah!!!
nachodog2's Avatar
Re: 1964 gmc
some more
Old 01-21-2011, 09:41 PM   #3
nachodog2
Hell yeah!!!
nachodog2's Avatar
Re: 1964 gmc
more
Old 01-21-2011, 09:47 PM   #4
nachodog2
Hell yeah!!!
nachodog2's Avatar
Re: 1964 gmc
the next morning we hit mooneyes x-mas show. and as it sits currently. still got a ways to go but i'm happy with it so far.
Old 01-21-2011, 10:46 PM   #5
mikesC10
mikesC10's Avatar
Re: 1964 gmc
Those Supreme's are tough.
mikesC10 is offline   Reply With Quote
Old 01-22-2011, 02:23 PM   #6
REDNOSE65
REDNOSE65's Avatar
Re: 1964 gmc
X2... WHAT SIZE ARE THEY???
Good lucking truck!
RED NOSE '65
LOS HITTERS C.C
DALLAS, TEXAS
The making of a Red Nose...
http://www.67-72chevytrucks.com/vboa...d.php?t=396518
REDNOSE65 is offline   Reply With Quote
Old 01-22-2011, 03:03 PM   #7
nachodog2
Hell yeah!!!
nachodog2's Avatar
Re: 1964 gmc
Thanx mike and rednose, they're 15 inch standards unilug. Believe 4 1/2 to 5 on 5.
Old 01-25-2011, 01:51 AM   #8
TwoFiftyShifter
Re: 1964 gmc
Very cool GMC. I like how in the first pic of the last pic, your parked behind a 55-59 that looks just like your truck at the start of thread, all multi colored and primered and whatnot. Anyways cool tires and rims and stance and I like the satin finish on the paint
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 02-23-2011, 12:05 AM   #9
nachodog2
Hell yeah!!!
nachodog2's Avatar
Re: 1964 gmc
been slowly workin on the truck, by slowly i mean hardly at all. i did manage to do some wiring in the cab though. added a new turn signal switch and indicator lights in the dash as i now have hazards too. got a steering wheel off a riviera and am gonna put it on this weeekend.
Old 03-03-2011, 09:34 PM   #10
Doug19
Re: 1964 gmc
I have a leaf spring gmc and plan on going the same route you did. What size blocks do you have and what size notch did you end up putting in? Also did you run into any major problems when installing your rearend setup.
Doug19 is offline   Reply With Quote
Old 03-03-2011, 11:53 PM   #11
Dinos63
chevy only
Dinos63's Avatar
Re: 1964 gmc
Nice work kat !! Dig it
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 03-03-2011, 11:59 PM   #12
coulter
coulter's Avatar
Re: 1964 gmc
nice work so far man!!! what r the specs on ur wheels? im wanting to get a set of those.. not real sure what offset to get
coulter is offline   Reply With Quote
Old 03-04-2011, 12:21 AM   #13
nachodog2
Hell yeah!!!
nachodog2's Avatar
Re: 1964 gmc
Those are 3" blocks that I'm running, you're gonna have to reset your pinion angle and probably raise your carrier bearing. I raised my carrier bearing with a spacer I made up at work, I believe an inch. Another thing was that my cross member hung way low and I ended up snagging it on a manhole cover, made for an unexpected surprise. I cut the lower portion of the crossmember out but that is only while I buy my lowered crossmember. Most critical part though is to tuck your exhaust, after lowering it that much, my exhaust caught something while in reverse and snapped my exhaust manifold causing me to yell out some choice words. Hope this helps.
Old 03-04-2011, 12:25 AM   #14
nachodog2
Hell yeah!!!
nachodog2's Avatar
Re: 1964 gmc
Those are just standard 15x7 4 1/2 to 5 on 5 unilug supremes, the rears are a little close to the insides of the bed but that's only because i used an '83 rearend. I'm planning on running a s10 rear which is narrower just so I can run 15x7 reverse.
Old 03-04-2011, 12:28 AM   #15
narx66gmc
Re: 1964 gmc
that height looks great!
Build Thread - Papa's truck build up
narx66gmc is offline   Reply With Quote
Old 03-04-2011, 12:34 PM   #16
nachodog2
Hell yeah!!!
nachodog2's Avatar
Re: 1964 gmc
Hey doug, i forgot to mention that it's a 10" notch.
Old 03-17-2011, 09:33 PM   #17
nachodog2
Hell yeah!!!
nachodog2's Avatar
Re: 1964 gmc
i started building a tonneau cover. have it mocked up but still need hinges and upholstery.
Old 04-28-2011, 08:14 PM   #18
nachodog2
Hell yeah!!!
nachodog2's Avatar
Re: 1964 gmc
update: picked up a used grille for $60 bux. slapped on a new rear bumper ( some adjustment still necessary. china made parts suck. ) picked up a new mooneyes steering wheel and added pleated vinyl to my home made tonneau cover.( hinges still pending )
Old 04-29-2011, 12:51 PM   #19
creep
Registered Loser
creep's Avatar
Re: 1964 gmc
Wow, a chrome grille for $60? You scored big time with that one!
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 10-13-2011, 05:04 PM   #20
ol_skool_chevy
ol_skool_chevy's Avatar
Re: 1964 gmc
Where did you get your pleated vinyl. Im doing a cover just like yours but I have not found the pleated vinyl in my area ( Oregon ).............I like yours.
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 10-13-2011, 07:35 PM   #21
nachodog2
Hell yeah!!!
nachodog2's Avatar
Re: 1964 gmc
Hey ol skool, thanx, i got the pleated vinyl locally, i think that any upholstery warehouse would carry it or be able to order it for you. The company i got it from is called Keyston and is located in North Hollywood, if it helps it goes by lightning white. Hope this helps.
Old 10-18-2011, 12:14 AM   #22
juanz1947
rusty 66
juanz1947's Avatar
Re: 1964 gmc
Dam look good homie like them supremes
1947 chevy fleetmaster
http://www.cbforum.net/forum/
1966 chevy c10 long bed
http://67-72chevytrucks.com/vboard/s...d.php?t=439219
1970 chevy impala custom
http://www.layitlow.com/forums/index...pic=349867&hl=
juanz1947 is offline   Reply With Quote
Old 10-18-2011, 11:31 PM   #23
nachodog2
Hell yeah!!!
nachodog2's Avatar
Re: 1964 gmc
Thanks juan, you're is looking good too, i really like your blinds, i need a set for mine.
Thread Tools
Display Modes
