Old 01-23-2011, 03:31 AM   #1
junkmen
junkmen's Avatar
U:joint specs and size #'s
Hey guy i could use some info on u:joint type's and sizes
OK here's what i have 82 GMC 1500 6.2L & 700R4 3 piece shaft and they are plastic injected joints in to 10 bolt diff I'm not sure what size joints these are next this is for a SWB conversion so my fiend gave me a one piece shaft that uses outer clips i think they are 1310 joints now the problem is it won't fit in the 10 bolt yoke so I'm thinking i need a 1310-1330 or 1310-1350 conversion joint any help is good thanks JM
junkmen is offline   Reply With Quote
Old 01-23-2011, 09:21 AM   #2
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: U:joint specs and size #'s
JM,
I take both old joints to my local NAPA store, They measure them and pull me the right size. A good parts guy has no problem with doing this....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 01-23-2011, 09:59 PM   #3
orbot
orbot's Avatar
http://neapco.com/n_products-catalogs.php
click on the joint cataloge and then to chevy section, theres some more info for convertion joints almost at the end.
orbot is offline   Reply With Quote
Thread Tools
Display Modes
