Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 01-24-2011, 12:21 AM   #1
ryans69chevy
torque wrench suggestions
I'am going to rebuild an engine this spring and need a good torque wrench. What do you guys suggest I get? I want something that will last along time.
Thanks for any suggestions.
ryans69chevy is offline   Reply With Quote
Old 01-24-2011, 01:39 PM   #2
Lee H
Lee H's Avatar
Re: torque wrench suggestions
I use Craftsman. They are relatively inexpensive and can be re-calibrated.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 01-24-2011, 03:17 PM   #3
treveiger
treveiger's Avatar
intersted also, broke the tip of mine off after barely using it... will defentally spend more money on the next one...
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 01-24-2011, 04:53 PM   #4
ryans69chevy
I have two both from northern tool. One is a 3/8" drive, the other is a 1/2" drive. They totalled $70. I figured they would be good enough to use, but they seem pretty sketchy. I'd rather spend a bit more now then mess up torqueing specs on my engine and ruin expensive parts.
I was also thinking of craftsman, but I don't know which one I'd get: microtork or digitork.
What's the process of re-calibrating? and how do you know if it's out of calibration or isn't "true"
Old 01-24-2011, 06:51 PM   #5
Indian113
Indian113's Avatar
I have snap-on and craftsman,up to about 45ftlbs I trust the craftsman. I wouldn't trust a motor to a HBF wrench. Just my OP.
Indian113 is offline   Reply With Quote
Old 01-24-2011, 10:34 PM   #6
crushermechanic
crushermechanic's Avatar
you get what you pay for in torque wrenches. i have 2 matco and 1 mac. i have had all for years and see regular use. they will all still hold 5% of the setting. the new snap on one are also really good.
crushermechanic is offline   Reply With Quote
Old 01-25-2011, 12:48 AM   #7
treveiger
treveiger's Avatar
How much should you look at spending for a decent one?
Old 01-25-2011, 12:08 PM   #8
vin63
It's Better With Nitro
vin63's Avatar
I've had my Snap-On torque wrenches for 20+ years, and I think they are between $200-300 these days.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-25-2011, 07:33 PM   #9
ERASER5
ERASER5's Avatar
You could try this bad boy! Sockets? Who needs'm? Just lock on to the bolt! Stripped bolt head? Who care! Just lock on!
Having trouble knowing how much torque to use? No problem! the new torque calibrations are easy to use and understand. Just look!
Get one TODAY!
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 01-26-2011, 12:09 PM   #10
Tim Christian
Tim Christian's Avatar
I have a couple of nice ones if interested?
Tim Christian is offline   Reply With Quote
Old 01-26-2011, 05:46 PM   #11
LooseCannon
Good torque wrenches aren't cheap. I did a lot of research on the subject about a year ago and decided on Precision Instruments.
LooseCannon is offline   Reply With Quote
Old 01-26-2011, 10:50 PM   #12
65Gregg
65Gregg's Avatar
How do you have the calibration checked?
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 01-26-2011, 11:15 PM   #13
BIGBLU 72
BIGBLU 72's Avatar
id like to know how to get the Craftsman ones recalibrated bc its off
68 C10 LWB 2/4 drop 406/th400/3.73posi
04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD
BIGBLU 72 is offline   Reply With Quote
Old 01-26-2011, 11:39 PM   #14
treveiger
treveiger's Avatar
Up here theres a guy that goes to shops and checks them out.
Maybe try going to a tool store and ask them because thats where i found out.
Old 01-27-2011, 06:41 PM   #15
dan76
There are folks whom provide torque wrench calibration....just ask a FAA AP mechanic.
I'm not pleased with the latest torque wrench offerings from Craftsman. Not only have they reduced the warranty to 90 days, but I have two with the plastic locking ring broken......with minimal usage.
Frankly I'm using a HF 3/8" drive with success. I've checked its calibration twice and it's holding true after 3 engine builds. I've looked at Precision, Matco and even Snap-on but haven't convinced myself to get a spendy new one especially with the demonstrated reliability of the HF unit.
dan76 is offline   Reply With Quote
Old 01-29-2011, 02:10 AM   #16
andyh1956
my 1/2" wrench is a snap on. but what's cool about it is it has a flex head. i would not have been able to do some of the work i have done with a straight wrench. it is 32 years old & only broke one set of gears in the head.
andy
andyh1956 is offline   Reply With Quote
Old 01-29-2011, 04:24 PM   #17
ryans69chevy
Get one TODAY!
Where would I buy one of these? It looks like it's pretty user friendly! haha thats hilarious.
Old 01-29-2011, 04:25 PM   #18
ryans69chevy
I just decided to go with snap-on. I'd rather spend a couple hundred dollars more now than spend it on ruined parts in my engine...
Old 01-29-2011, 04:48 PM   #19
Indian113
Indian113's Avatar
Smart move!
Old 01-29-2011, 10:41 PM   #20
truckdude239
truckdude239's Avatar
snap-on only way to go
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 01-29-2011, 11:46 PM   #21
Sicklajoie
The Niner
Sicklajoie's Avatar
Seems like everyone's got that same problem with the locking ring.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 01-30-2011, 12:37 AM   #22
treveiger
treveiger's Avatar
Ya i might just break down and buy a good one or borrow one from someone i know
Old 01-30-2011, 07:34 PM   #23
piecesparts
Parts and more parts
piecesparts's Avatar
Agree, totally! I have a couple different Crafstman torque wrenches and I have them checked regularily at my work place. They are a of good quality and stand up real well.
Frank
piecesparts is offline   Reply With Quote
Old 04-24-2011, 01:41 AM   #24
PatrickGMC70
PatrickGMC70's Avatar
YEah, mine broke just sitting in the case.
PatrickGMC70 is offline   Reply With Quote
Old 04-24-2011, 07:35 PM   #25
bighaas79
I've got the 3/8 and 1/2 inch digital torque wrenches with the angle meter built in from snap on. I think i have just over $1000 in the 2 torque wrenches. But they are dead accurate, don't have a spring in em to be stretched out, and can be recalibrated, but have yet to need it done to either of them. And with the angle meter in it, it is way faster than setting up a mickey mouse angle finder seperate from the wrench. And with the push of the same button goes from inch/lbs to ft/lbs to n/m to angle. I make a living with them however and probably wouldn't be suited for the hobbiest.
bighaas79 is offline   Reply With Quote
Thread Tools
Display Modes
