01-27-2011, 09:54 PM | #1 |
cpp c notch
well i got my c notch and started to put in today..got all rivets out and went to mock up and it doesnt fit exactly right. ive seen a couple o fpeople discuss this before, basically the way the instructions say to line up doesnt have the axel lay completly center in the notch. so i was just gonna cut the notch the way it should be, and adjust accordingly, ie: drill new holes in notch..then weld in when done. anyone else run into this problem, and how did you go about it. any help is greatly appreciated, im gonna finish it up tomorrow so i was hoping for quick feedback. lots of smart guys on here.. thanks
01-27-2011, 10:18 PM | #2 |
Re: cpp c notch
Some pics
01-28-2011, 12:29 PM | #3 | |
It's Better With Nitro
Re: cpp c notch
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes Last edited by vin63; 01-28-2011 at 12:29 PM. |
01-28-2011, 12:48 PM | #4 |
67-72 parts collector,…
Re: cpp c notch
I bet it's a little bit forward in the notch,... because to the 2" drop blocks.
01-28-2011, 01:02 PM | #5 |
Re: cpp c notch
I love this pic. Brings back many memories of working in the street .
01-28-2011, 01:11 PM | #6 |
Re: cpp c notch
X2, that little bit will make a difference. As long as it "fits" is what is important, if its not exactly center it shouldn't matter provided you make the clearance.
Trevor "You already said spite" |
01-28-2011, 03:27 PM | #7 |
Kill Bill...et
Re: cpp c notch
Looks like you're doing it right. Jack the axel up to the frame and mark a vertical line on the frame to mark the front and rear of the axel will be located. I made a cardboard template of the notch and just lined it up to my marks. If you've got the rivets drilled out, the hard part is done! Good luck
01-28-2011, 03:58 PM | #8 |
Re: cpp c notch
i drilled the rivets and installed ... it wasn't forward or backward enough off centerline to make any real difference ... and I'm using 1 1/2" blocks.
p.s. you must have some real understanding neighbors. |
01-28-2011, 06:09 PM | #9 |
Re: cpp c notch
haha thanks guys but actually when i had the notch mocked up per instruction..looking at it from the drivers side the axel would hit the far right side of the notch so rearward,,towards the taillights. i made the cardboard template and drew it on the frame and when i raised the axel to the frame it looked like it was going to hit the "notch" almost immediately once passed the frame.
like i said i was gonna just cut it where it should be and adjust with drilling holes in the cnotch to bolt into the existing frame holes. |
01-28-2011, 09:07 PM | #10 |
Kill Bill...et
Re: cpp c notch
Exactly...Use the CPP instructions for a starting point and adjust from there as needed. I had to adjust mine a bit too. More drilling....great times!
Oh yeah...I agree with Shane. Understanding neighbors or folks that can appreciate a nice pickup fix-up. Last edited by stevencvn72; 01-28-2011 at 09:32 PM. Reason: thinking....thinking....thinking |
01-28-2011, 10:18 PM | #11 |
Re: cpp c notch
most the neighbors are cool..the mail man loves it, usually everytime im workin on it he comes by and checks it out. well i got it done, for the most part. the drilling was the part that was the hardest. broke two bits so i just need to drill three last holes and ill be done. not to bad tho at all. its a good product for sure im happy with it.
01-28-2011, 10:21 PM | #12 |
Re: cpp c notch
the only thing to modify now is the panhard bar mount on the axel..you can see in the pics its gonna hit. i wanna fab up some kind of mount that will attach to my lowering block somoehow without being wedged between the block and trailing arm like the cpp kits. only reason because i dont think i have that much room on my u-bolts. heres some pics.
01-28-2011, 10:22 PM | #13 |
C/10 junkie
Re: cpp c notch
Looks good man! I did mine with the bed on and its a leaf spring rear end.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
01-28-2011, 10:27 PM | #14 |
Re: cpp c notch
i got to applaud you on doing that with the bed on man..it was a pain in the rear with it off!! haha looks good
01-29-2011, 02:50 AM | #15 | |
Re: cpp c notch
01-29-2011, 08:22 AM | #16 |
Yellow truck club
Re: cpp c notch
Where are your safety glasses !!!!!!
................................................................ Brian ...... My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW 59 Chev Apache PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
01-29-2011, 09:26 AM | #17 | |
Re: cpp c notch
They also save your wrist... they don't tend to grab and yank the drill out of your hand like a regular twist drill bit does. Another tool that you won't know how you lived without. Last edited by lakeroadster; 01-29-2011 at 09:27 AM. |
01-29-2011, 11:13 AM | #18 |
Happy to be here
Re: cpp c notch
Agree on the step bit with some advice. Get a good one! There are cheap copies out there but they dont last long in a large size application.
Posted via Mobile Device |
01-29-2011, 12:39 PM | #19 |
Re: cpp c notch
You got the back low, now.
So you really need a set of rear shock relocators to stand those rear shocks up! Also buy a set of quality drop shocks. If you can't fab up panhard bar mount, I highly recommend ECE's Super Track Bar.
01-29-2011, 06:53 PM | #20 |
Re: cpp c notch
01-29-2011, 06:54 PM | #21 |
Re: cpp c notch
01-29-2011, 06:58 PM | #22 |
Re: cpp c notch
well i dunno what to about that..i modified my old top shock mount by just moving the hole up and over, i think it gave me an inch or so. but i havent done anything with the bottom ones yet. i would like to see some pics of anyone with the shock relocaters, do i really need them. i also have some brand new monroes i was gonna put on, 31000's i think. they look like they will work good, ive heard some talk about the stiffness of the drop shocks. i think ill try these and go from there. but im still torn about the relocaters.
01-29-2011, 10:25 PM | #23 |
Re: cpp c notch
The 33100 shock's are too long for a lowered truck.... check out this thread: http://67-72chevytrucks.com/vboard/s...t=shock&page=2
Additionally, based on the data I recieved from Monroe the shocks must be mounted within 30 degrees from vertical or the shock valving may not work as designed. In order to find shocks that are affordable and that will be functional I researched alternative Monroe shocks, contacted Monroe in regards to shocks that are applicable to our lowered trucks (Monro-Matic Plus P/N 32207, see post #29 on linked thread) and will be fabricating some alternative bolt in upper shock mounts (see post #36 on linked thread) within the next couple of weeks. Here is the plan... pretty simple. It's a bolt in bracket that replaces the factory upper shock mount. Stay tuned..... Edit 02-06-2011: Fabricated the new upper mount, see post #56 of my build thread. Last edited by lakeroadster; 02-06-2011 at 12:43 PM. |
01-29-2011, 10:34 PM | #24 |
Re: cpp c notch
With the rear shocks layed that far over,... all they do is "pivot" on the mounts.
The don't compress and rebound.
01-30-2011, 02:15 PM | #25 |
C/10 junkie
Re: cpp c notch
Hey in relation to the lowered rear shocks. I have found that most companies will sell you lowered rear shocks, and this is what I did, but if you check there part numbers they are the same numbers as [U]stock front shocks.[U] So another words I bought some stock Monroe front shocks and installed them on the rear of my truck which was dropped 7 inches.
Thread Tools | |
Display Modes | |
