Old 01-30-2011, 08:27 PM   #1
brans72
automatic crossmember?
So got the 700R4 in the truck got the crossmember in the truck now how the heck do I drill holes with the cab still on the frame? 67 SWB 350/700R4 engine moved forward. Thanks Brandon
brans72 is offline   Reply With Quote
Old 01-30-2011, 08:30 PM   #2
haplis
Re: automatic crossmember?
are you trying to attach the trans cross member, if so it should bolt right into the exsisting cross member holes.
haplis is offline   Reply With Quote
Old 01-31-2011, 07:15 AM   #3
brans72
does not line up when moving engine forward and 700r4 but ny tips to make it would be great!
Old 01-31-2011, 08:53 AM   #4
NicoSlam
I just finished doing what you are asking. Install Cross member in final location and measure/ mark a line on the chassis frame where the crossmember member sat. Remove crossmember and place underneath frame and align with mark. Then simply identify holes with sharpie and drill. Reinstall crossmember inside chassis frame.
NicoSlam is offline   Reply With Quote
Thread Tools
Display Modes
