Old 02-04-2011, 10:27 AM   #1
JMac11
JMac11's Avatar
Sunvisors with soft top??
My Blazer had no sunvisors when I got it, soft top only. How can I put them back without a hard top???
JMac11 is offline   Reply With Quote
Old 02-04-2011, 12:24 PM   #2
tubbedII
needs more $$$
tubbedII's Avatar
Re: Sunvisors with soft top??
They bolt into the windshield frame with 2 bolts. There's a 3rd that goes into the hard top, but you don't need to have it in. I'm still looking for the bolt size, so post back if you find them!
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 02-04-2011, 12:41 PM   #3
JMac11
JMac11's Avatar
Ok... will look and see if the hole for the 3rd is a pass thru on the windshield fram, if so I will thread some stock and just use what I can find for it.
Old 02-04-2011, 01:33 PM   #4
tubbedII
needs more $$$
tubbedII's Avatar
The 3rd is hole is verticle, so it doesn't go through the windshield frame at all.
I don't have a pic of my own, but found this one on the board. The holes circled in red go against the winshield frame. When it's mounted, the hole circled in blue will be straight up and down and lines up with a hole in the hard top. With a soft top, you probably just won't use the blue one at all...that's what everyone does with the top off at least.
1970 2wd Blazer
Old 02-04-2011, 04:18 PM   #5
jasons
not enough hours in the day
jasons's Avatar
Just to point it out, Blazers use different visors than the pickups.
65 K-10 Short Step
68 C-50
70 K-5
85 K-10
& piles of spare parts
jasons is offline   Reply With Quote
Old 02-04-2011, 04:49 PM   #6
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I leave my visors on when running the soft top.
If you don't plan on running a hard top, you can use the truck/suburban visors.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 02-04-2011, 05:51 PM   #7
tubbedII
needs more $$$
tubbedII's Avatar
Really?! I bought a set of truck visors and put them up and couldn't see how they lined up with the existing holes...that's when I found out blazers were different. Do you have to make new mounts?
1970 2wd Blazer
Old 02-04-2011, 06:27 PM   #8
bouncytruck
SKINNY TIRES RULE!
I could be wrong but, I swear I've seen Blazers with truck visors in the past.
bouncytruck 1972 K5
Old 02-04-2011, 06:39 PM   #9
blazintowers
blazintowers's Avatar
they bolt to the top of the windshield header, don't need the top mounted to install them...
blazintowers is offline   Reply With Quote
Thread Tools
Display Modes
