Old 02-04-2011, 10:47 PM   #1
THIRSTY
Please help
i have a 72 c10 with a stock 454 in it. It has a 750 edlebrock prefomer carb and an edelbrock aluminium intake. Thats it. it has dual exhuast (no headers) everything else is stock. I want some opinions on what i should do to get this 3800 lbs of steel moving! I'm new to ths type of thing and don't know much. Thanx
THIRSTY is offline   Reply With Quote
Old 02-04-2011, 10:50 PM   #2
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: Please help
If the engine is operating properly the first thing I would do is change the rear axle ratio to a 3.73 Most likely it is a 2.73 or 3.08 factory. Then I would swap in a 700r4 trans and the acceleration will be even better because the first gear ratio is beter than the turbo350/400.
--Josh
Old 02-04-2011, 11:01 PM   #3
THIRSTY
Re: Please help
Thank you for the advice
Old 02-04-2011, 11:09 PM   #4
THIRSTY
Re: Please help
AJs72K5... Do whatever you did again cause my computer messed up
Old 02-04-2011, 11:09 PM   #5
AJs72K5
AJs72K5's Avatar
Re: Please help
In addition to the rear end gearing and the deeper 1st gear the 700r4 has, I'd put some headers on that 454 to help it breathe better, upgrade to HEI,.... The list a can go on and on. Depends on how deep your pockets are.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 02-04-2011, 11:13 PM   #6
THIRSTY
Re: Please help
don't care bout money. The truck gets what she wants
Old 02-04-2011, 11:16 PM   #7
THIRSTY
Re: Please help
all i know is i want the hood to still close and the rear end to be able to handle whatever i do to the motor.
Old 02-05-2011, 12:18 AM   #8
blazintowers
blazintowers's Avatar
Re: Please help
headers for sure, if she's just for around town some 4.11's in the rear, a Barry Grant Street Demon Carb, MSD HEI, mostly bolt on's, without swapping the cam and heads. Maybe some NOS, 100HP shot.
blazintowers is offline   Reply With Quote
Old 02-05-2011, 01:03 AM   #9
72lb4x4
Re: Please help
I would think that a 454 truck would run pretty good as is. Maybe before throwing a ton of money at it you should figure out if its running as well as it can now.
Dual exhaust and manifolds is a nice reliable performance compromise. Headers like to leak and blow out gaskets.
I'd suggest a tuneup, clean the fuel system, and check the timing.
72lb4x4 is offline   Reply With Quote
Thread Tools
Display Modes
