Old 02-05-2011, 11:34 PM   #1
72supermike
attaching side moulding question
Ok, so I have upper and lower trim to put on my truck. I was wondering what you guys have done to attach it without doing it the original way with holes and clips etc. Like what double sided tape stuff have you used that worked really good and easy and where do I get it? Thanks!
72supermike is offline   Reply With Quote
Old 02-06-2011, 12:05 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: attaching side moulding question
I used the 3M with the red backing. I used the original stick on molding clips with the new tape. I would still recommend drilling holes in the front and back and using the snap in clips in those. It not only makes the ends more secure but also makes it a lot easier to position the trim to stick it on.
LockDoc
Leon
Old 02-06-2011, 12:21 AM   #3
Zoomin
Man of Mini-Talents
Zoomin's Avatar
LockDoc
This.
I got the 3M tape, sold in most auto paint stores.
Zoomin is offline   Reply With Quote
Old 02-06-2011, 02:13 AM   #4
72supermike
thanks guys. i'll check out the auto parts/paint stores.
Old 02-06-2011, 02:48 AM   #5
67chevy1series
67chevy1series's Avatar
~i wouldnt trust double sided tape to hold trim that will have wind resistance on it and water i love the clips .......
67chevy1series is offline   Reply With Quote
Old 04-26-2013, 01:39 PM   #6
sasquatch58
classic chevy trucks restoration parts have push in style clips so you don't have to deal with putting the nuts on to the threaded studs.they are nmetal just lke originals but just snaps into the holes..a xdefinate pain in the axx saver.part # is 62-891A for short bed trucks.but they have the kit for long beds also.
sasquatch58 is offline   Reply With Quote
Old 04-26-2013, 02:42 PM   #7
Coley
Coley's Avatar
Smile Re: attaching side moulding question
I definitely agree with LockDocs suggestion about making sure you have at least (2) fasteners per moulding. One at the leading edge and one at the trailing edge. Do the rest with the adhesive tape and if it was mine, I'd try to hit an adhesion point about every 6"-8" over the length of the moulding.
Don't be afraid to drill a hole or two to put the 'hard fastener' clips in. Just make sure you measure it up correctly and carefully...then after drilling, touch it up, paint it, then seal it with some grease when you put the fastener.
That way you'll avoid the rust worm getting a hold.
Good luck.
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Thread Tools
Display Modes
