03-14-2003, 05:28 PM | #1 |
removing front clip
I should know this by know, and I have a good idea of all the bolts that have to be removed but just to make sure...... where are all of the bolts i need to remove to take the front clip off, including the inner fenders.
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
03-14-2003, 05:46 PM | #2 |
Fabricate till you "puke"
I just remove the hangerstraps,unclip the harness, & pull 2 pins.....that might be "cheatin " tho Remove the cowl(2 bolts on ea side, a handfull of screws,& the wipers). There are 2 bolts on the top on ea fender, & 1 on the bottom ea. 1 bolt ea on the inner fender to the cab, the brace on the inner (around the steering shaft), & the 2 front cushions (rad support). unhook the harness, & you should be good to go(I think that covers it). good luck,crazyL
Thread Tools | |
Display Modes | |
