02-06-2011, 08:40 PM | #1 |
454 sleeved??
I just bought a 454 from my brother who bought it from the boneyard. It came from a 1989 Chevy 3500 4WD. I took it apart and found it had a broken crank and number 2 cylinder has 2 deep gouges. So how far can a 454 be bored out and is there a way to sleeve the cylinder. I had this done to a 400 smallblock years ago and it worked great for many years after. Any help would be great fellas. Thanks in advance.
Patriot Last edited by Patriot; 02-06-2011 at 08:40 PM. |
02-06-2011, 11:08 PM | #2 |
Re: 454 sleeved??
I think .060 over is as big as you can go. Not sure about sleeving.
02-06-2011, 11:51 PM | #3 |
Re: 454 sleeved??
i know you can go 70 over might be able to go even more than that...
if it's in too bad of shape.. best to look for a new block? sleeving isn't exactly cheap... and a newer block would be the better option imo.
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
02-07-2011, 12:14 AM | #4 |
Re: 454 sleeved??
I've seen an 1/8" over (.125") bored 454 run before. But it was in a drag car, alcohol and a lot of N20.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! |
02-07-2011, 12:46 AM | #5 |
Re: 454 sleeved??
Yes they can be sleeved. right back to what ever size piston you are using in the other holes. But i would shop around and find a shop that does it regularly.
nickle and dime |
02-07-2011, 03:00 AM | #6 |
Re: 454 sleeved??
i have engines sleeved all the time. around here it costs about $100 a hole or better. i had all eight holes on a 7.3 powerstroke sleeved & it cost a smooth $1000.
andy |
02-07-2011, 03:48 AM | #7 |
Re: 454 sleeved??
02-07-2011, 08:00 AM | #8 |
Re: 454 sleeved??
Have the block sonic checked so you can see how far you can go. ALL 454's will take .060 over, most will go to .100 over stock. If all the rest will clean up at .030 or .060, I'd have it sleeved and go to that dimension. As long as your shop knows what they're doing, a sleeved cylinder is no weaker than a stock one and the sleeve won't move a bit after installation.
Sounds like a piston pin managed to get loose and cut some grooves in the cylinder wall, I see it quite often. |
02-07-2011, 11:42 AM | #9 | |
Re: 454 sleeved??
Thanks for your response. |
02-07-2011, 01:39 PM | #10 |
Re: 454 sleeved??
Have your shop check to see if they think it will hone out at .030. If it has any ridge at the top of the bore, it probably won't. At any rate, I think I'd find out what the rest of the bores will clean up at and go there, there's not really any good reason to go all the way to .060 if you don't need to, thicker cylinder walls = better cooling and probably a better ring seal.
If those pin grooves don't go all the way to water, you sure won't have anything to worry about, just look at a sleeve as a way to resurface the bore, it won't be in contact with water. |
Thread Tools | |
Display Modes | |
