Old 02-12-2011, 06:07 PM   #1
eagleuh1
eagleuh1's Avatar
Trailing arm brackets?
Anyone sell the brackets for mounting trailing arms. Looking to convert my leaf spring 3/4 ton to trailing arms with bags. Empty she rattles my fillings loose. Looking for the brackets that go on the crossmember, and weld on mounts to convert the D60 to go on the swingarms. Thanks.
eagleuh1 is offline   Reply With Quote
Old 02-12-2011, 08:24 PM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: Trailing arm brackets?
I bought my perches from ECE when I swapped in my five lug axle. I don't know that I've ever seen the brackets that hold the trailing arm to the crossmember. I think you'd have an easier time just replacing the crossmember itself. I would have given you mine, but I hack it to pieces when I took it out to put in the lowered crossmember that i got from ECE as well. You may be able to find a used one on the parts board and save yourself some coin. Hope this helps.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 02-14-2011, 01:38 AM   #3
FirstOwner69
FirstOwner69's Avatar
Are these what you are looking for? I saw them on eBay the day I read your post. They are not mine.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
FirstOwner69 is offline   Reply With Quote
Old 02-14-2011, 02:53 AM   #4
fixit-p
fixit-p's Avatar
If you can fab them, here is a drawing all you need is some 4 x 3 x 3/16" tubing.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 02-18-2011, 10:57 AM   #5
eagleuh1
eagleuh1's Avatar
No, those don't look like what i'm after. I'm wanting the hangers that attach the trailing arms to the crossmember. Wheres the drawing?
Thread Tools
Display Modes
