Old 02-13-2011, 12:25 AM   #1
Sir Fisher
Sir Fisher's Avatar
Are steering stabilizer needed??
i see some trucks with one and some trucks with two... are steering stabilizers needed??
thanks,
wayne
1970 Chevy K20 Custom Camper
1996 Chevy Impala SS
2008 Chevy Avalanche LT3
2003 Honda Accord EX
2001 Hewes Redfisher 16 Fighting Lady Yellow
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=324118
Sir Fisher is offline   Reply With Quote
Old 02-13-2011, 12:34 AM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Are steering stabilizer needed??
You'll get differing answers on this.... in my experience, they are not required on anything near stock and in good condition. A steering stabilizer will help mask problems such as worn-out front-end components, but that's about it. They may be more useful on something lifted and with bigger tires, I don't know. I have 33/12.50s and a 2 1/2" lift and have run with and without a SS. The only difference I notice is a bit more steering resistance with the SS in place, and I have zero problems with it removed.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 02-13-2011, 02:07 AM   #3
dammitmitchell
the pollock
dammitmitchell's Avatar
depends on what style of steering you have, if you cross over steering you dont need them.
if you have standard steering you definatley need them
they dramatically reduce the amount of bump steer you get. Also tire height is important, i absolutely have to have them im runnin 8in of lift with 37"s
the small bumps will jerk the steering wheel around..
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 02-13-2011, 11:07 AM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Bump steer is greatly affected by how much offset / backspacing your wheels have.... also by tire width and a few other tire details (construction, tread, inflation). My (basically stock) K20 doesn't have noticeable bump steer, with or without the SS.
- Mike -
RIP El Jay
Old 02-13-2011, 07:40 PM   #5
dammitmitchell
the pollock
agreed.
stock our trucks come with a single stabalizer , the dual set ups are pretty aftermarket dealys that work pretty well.
but no need to spend the 200 on them if you dont have a descent lift and anything past 35s
Army vet 02-08
Old 02-15-2011, 01:03 PM   #6
D.PASSMORE
One of the First
D.PASSMORE's Avatar
All my 72 4x4's that I've owned have stock brackets for a steering stabilizer.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 02-15-2011, 02:15 PM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I learn things from this board all the time. Right now I'm confused, when I bought my truck in 1977 it had no SS, not even brackets for one. Maybe the PO removed it for some reason? I installed an aftermarket SS not because of any problems, but simply because I thought it should have one.
- Mike -
RIP El Jay
Old 02-15-2011, 04:07 PM   #8
dammitmitchell
the pollock
i have an 83 4x4 it's a single stabilizer behind the rod that attaches to the axle tube itself.
what have you done to your truck? lifted tires? what year? what offset of rims?
got a picture?
that woudl better help us let you know if you need one or not.
Army vet 02-08
Old 02-15-2011, 04:20 PM   #9
dammitmitchell
the pollock
look right next to the differential
that bracket is where the stock steering stab would be.
it connected to the bar with U bolts.
Army vet 02-08
Old 02-15-2011, 10:30 PM   #10
Sir Fisher
Sir Fisher's Avatar
Can't tell you what size tires or wheels or the off set yet, because i'm still looking for wheels and tires right now; here is a pic of where i am in my build stage...
Old 02-16-2011, 12:03 AM   #11
dammitmitchell
the pollock
well id get a pair =-)
you can also order the boots in pretty much any color you would like i think black boots with a black paint on the stabalizers would benefit the overall look and not distract from that beautiful green
Army vet 02-08
Old 02-16-2011, 12:13 AM   #12
rayfinseats
Good question. Mine is missing on my 83 k10. Glad someone asked.
rayfinseats is offline   Reply With Quote
Old 02-16-2011, 11:29 AM   #13
I consider steering stabilizers as necessary,just like shocks. You can run without them but with them is an improvement. When someone says "steering stabilizer" I don't automatically assume they mean a dual or aftermarket one. I've always added them to pre-72s and '72-ups already have them. I always add dual gas-charged to trucks with 12.50s or bigger to compensate for the larger size. They cut back on rut-steer and shimmy even on a tight front end. I see no negative results from using them so I never considered not running one.
Old 02-16-2011, 05:27 PM   #14
68panelman
68panelman's Avatar
My 72' k-20 had one stabilizer,it started leaking,i removed it,did not replace and felt zero differance,4 inch springs 2" body 35inch tires.
68panelman is offline   Reply With Quote
Thread Tools
Display Modes
