Old 02-14-2011, 01:25 PM   #1
fun in dirt
fun in dirt's Avatar
How many leaves should I run in 56" springs?
This set of 56" I was planning on using for rear of my Blazer has 9 leaves - 8 regular & 1 overload I think. They're out from under a single wheel 1ton CUCV. So I'm sure they're pretty stiff as is. I'm gonna take them apart & clean/paint them anyway, so which leaves & how many should I take out for a better ride?
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 02-15-2011, 02:56 PM   #2
fun in dirt
Re: How many leaves should I run in 56" springs?
Okay I'll try saying it another way...
Let me see some pics of other folk's 56" springs; how many leaves are in them?
'85 K30 "Big Nassy"
'06 C1500 WT...DD
Old 02-15-2011, 03:06 PM   #3
drunkbus
New Member
drunkbus's Avatar
Here's what I have. It looks like there are 8 in mine. These are out of a 3/4 ton.
drunkbus is offline   Reply With Quote
Old 02-17-2011, 11:27 AM   #4
fun in dirt
How rough is the ride? I don't mind & do like it a little stiff but not too rough.
'85 K30 "Big Nassy"
'06 C1500 WT...DD
Old 02-17-2011, 01:43 PM   #5
drunkbus
New Member
drunkbus's Avatar
Compared to what? The only thing I have to compare it to was the 40 year old stock warn out suspension that was pretty rough as it was. Any lifted vehicle is going to be a little stiff but I don't think this setup is bad at all. I would think it would have to be a better ride than using 6" lift springs in the rear and personally I would never use blocks so this was my choice.
Old 02-26-2011, 12:06 PM   #6
WHITE-NOISE
WHITE-NOISE's Avatar
i went with 56 inch springs off a cucv truck for my 68. the spring center pin isnt the same as the factory spring so i had to run the springs backwards and use an 1.5 zerorate block from diy4x4 to move the axle forward, but its still a half an inch back from factory spec, but i doubt anyone will even notice it. i used the rear hangers and shackles from the same truck. over all it ended up giving me a little more than 4inches of lift in the rear. as for the ride of it, i have no idea yet as im not done building the truck :waah
cucv springs (top) and stock 68 spring (bottom)
after i finished up getting everything measured out and bolted up.
i took the top overload spring and spacer block out and left everything else on, theres 9 leafs left in the pack.
gave it some army green accents to set it off
WHITE-NOISE is offline   Reply With Quote
Thread Tools
Display Modes
