S10's and Ebrakes...
I'm currently using a highly modified S10 pedal ebrake setup in my conversion and was seriously looking at the old style hand levers. There's a guy down the road that has one in an old 1 1/2 ton that I've been eyeing.
I know they're normally in the middle of a cab and with modern transmissions wouldn't fit well... anyone ever built one into an S10 conversion with it beside the outboard side (to the left of the brake pedal)? Cheers, Ted.
'51 Chevy Build - In the design stages Aut viam inveniam aut faciam - I will either find a way or make one. If you don't have time to do it right the first time, when will you... My new build - https://67-72chevytrucks.com/vboard/...70#post8958970 |
vintage car junkie
Re: S10's and Ebrakes...
Ive been thinking of doing this, ive got a setup out of a VW bus I was going to use but im not sure how/where to set it up with the TH350 in the way. It looked like it would work out perfect though with the factory S10 cable setup.
1950 chevy truck, s10 swap, bagged, v8, 18s My build: http://67-72chevytrucks.com/vboard/s...d.php?t=392761 |
How about a hand brake that's attached to the bottom of the dash like on 60's trucks? I'm not sure you'd have enough room over by the kick panel...but I'm guessing you're plenty capable of making something that will work...
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
Dunno... there's just something about that hand brake with the lock lever on the top...
Thread Tools | |
Display Modes | |
