Old 02-21-2011, 10:52 PM   #1
Mikey72
4x4 rear cab mount measurements
I have a 72 chevy 4x4 that was a lwb converted to swb. The frame was cut in front of the rear cab mounts for some reason. When i took my bed off to replace the floor some friends of mine noticed the drivers side rear cab mount was welded back to the frame about a 1/2 inch higher than the passenger cab mount which was onnly held on by two bolts that was drilled in. Does anyone know the measurements from the bottom of the frame to the bottom of the cab mount or something of better detail so i could get this horrible mistake fixed. Thanks again everybody.
Mikey
Big_Mac
( )(_.)(._)( )
( ) \___/ ( )
Mikey72 is offline   Reply With Quote
Old 02-21-2011, 11:40 PM   #2
Booya
Booya's Avatar
Re: 4x4 rear cab mount measurements
Here is mine, original 72 SWB 4x4. Looks like both sides are the same 1" from the top. Hope this helps. Bill
Booya is offline   Reply With Quote
Old 02-22-2011, 07:01 AM   #3
Mikey72
awesome, thats exactly what i needed to see. I really appreciate it. Thank you Bill
Big_Mac
( )(_.)(._)( )
( ) \___/ ( )
Old 02-22-2011, 10:47 AM   #4
Booya
Booya's Avatar
No problem, glad I could help...
Old 02-22-2011, 10:32 PM   #5
mstrav1973
mstrav1973's Avatar
You may have to use washers that are as large as the bushing to shim out the differance.
Matt
72 chevy k-10, swb, auto, 35's, rally's, posi, 4" lift, 2.5" old style 40 series flows with headers and crossover pipe and some other stuff!!
mstrav1973 is offline   Reply With Quote
Thread Tools
Display Modes
