Old 02-24-2011, 12:57 AM   #1
moovinmetal
moovinmetal's Avatar
1965 gmc frame motor mounts
Where can I find the correct pair of frame engine mounts for a 1989 350 with a 700 r4 installing into a 1965 gmc 1/2 ton swb. I have installed with mounts in the rear holes but, must have the incorrect mounts because the trans hits on the seam below the firewall and cannot install the HEI. Thanks,Jack
moovinmetal is offline   Reply With Quote
Old 02-24-2011, 01:49 AM   #2
Captainfab
60-66 Nut
Re: 1965 gmc frame motor mounts wanted
Those are the correct frame brackets for a small block in the '63-'66 trucks. Do you have the small hump trans cover? The HEI will fit.....it is close but it does fit. So it sounds like you are wanting a set of small block '67-'72 frame brackets?
Old 02-24-2011, 01:50 AM   #3
Rannos
Rannos's Avatar
From what your saying I am guessing you used the rear mounts from your old engine on the later model engine. What you need is the later model engine perches and mounts that mount closer to the front of the engine block. You can either run some out of 67 and newer truck or use aftermarket. CPP makes a nice tubular engine perch that's a direct bolt in and comes with hardware and is cost effective. With them you can run the later model engine mounts and it gives you more clearance for exhaust and what not.
Rannos is offline   Reply With Quote
Old 02-24-2011, 01:57 AM   #4
Captainfab
60-66 Nut
The CPP tubular brackets utilize the '60's style passenger car motor mounts.
Old 02-24-2011, 09:10 AM   #5
moovinmetal
Will the small block 67-72 mounts line up in the front position with all holes? Ireally do not want to drill any holes. If I move forward to the front holes it appears the transmission will have clearance needed. It appeRs to have the small hump. Thanks for the help on this.
Old 02-24-2011, 09:18 AM   #6
moovinmetal
I just called the man I got my mounts from he advised they are from 67-72 truck.
Old 02-24-2011, 10:23 AM   #7
padresag
sometimes one has to manipulate the floor seam that protrudes down from the floor at the b/housing area.. if you require new body mount insulators or if you have some rust in that area (cab mounts,floor), repairing the sheet metal in that area will also help to put the body back in it's proper position.
ron
padresag is offline   Reply With Quote
Old 02-24-2011, 10:34 AM   #8
BarnFind
There are three holes on the top of your frame. The 60-66 stands use the back two holes and the 67-72 use the front two holes. Though the two perches look similar and will both bolt right up to your frame, the 67-72 have a tighter bend on the end that bolts to the crossmember. Sean
BarnFind is offline   Reply With Quote
Old 02-24-2011, 11:49 AM   #9
kieth
kieth's Avatar
I recently used engine mounts from a 91 suburban (same as 87 pickup) we did use the front 2 holes in the frame but ended up having to modify the location of the rubber block (lower in the bracket) and we notched the frame to keep all dimensions the same as the suburban donor) it worked great and no interferance with the tbi 350 700r4 combo and the cab. Kieth
kieth is offline   Reply With Quote
Old 02-24-2011, 12:07 PM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
Please note that you must be a supporting member to post classified item. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-24-2011, 10:26 PM   #11
BarnFind
I dont think anyone is trying to buy or sell anything via this thread. I thought he was just asking for a little info. Sean
Old 02-25-2011, 12:22 AM   #12
Andice
Andice's Avatar
Right?
Andice is offline   Reply With Quote
Old 02-28-2011, 05:38 PM   #13
SFTorange
SFTorange's Avatar
I'm going to revive this thread with a few questions of my own. My 1966 C-20 came from the factory with a 283 andhigh transmission hump. I installed a 350 with an HEI distributor in place of the 283, and the clearance was tight, but manageable. While doing my frame-off I decided to use a set of 67-72 engine perches to move the engine forward 2.5 inches. This was relatively easy since I was installing a 700r4 and was going to be doing driveline modifications, trans crossmember relocation, etc anyway.
I've got the engine mounted with the new perches in place, Luckily, the difference in length between the Turbo 350 and 700r4 offset each other and my driveline is still the right length. However, my original dual exhaust won't fit. The stock ram's horn manifolds dump straight down over the front suspension crossmember, and the bend in the exhaust is too deep now. There is 6" of clearance between the bottom of the manifold and the crossmember. I went to a local custom exhaust shop today, and the owner told me that he most likely cannot bend exhaust to clear the suspension crossmember with my stock manifolds. He strongly recommended that I go back to my original engine mounting setup in the rear holes.
I'm trying to figure out if he knows what he is talking about, or if he is just opinionated. If I move back to the original engine perches, the exhaust will clear, but the HEI will be tight, and some people have clearance trouble with the 700r4. If I stay in the forward location, I'll have trouble with the exhaust.
My main question is: Do trucks that came from the factory with a high transmission hump have more HEI/700r4 clearance than trucks with a short hump? It seems like some people have trouble with clearance and some don't. I'm tempted to move the engine back, but then I will have to modify the driveline and deal with tight clearances on the distributor. I can't remember for sure how close it was before, but before I move it back, I want to make sure that the transmission will clear the firewall.
Secondly, has anyone gotten exhaust to fit with stock manifolds and the engine in the forward perches? The exhaust guy says that he'll try to bend the exhaust to fit, but will make no guarantees.
I'm open to suggestions, what do you think?
SFTorange is offline   Reply With Quote
Old 02-28-2011, 07:08 PM   #14
padresag
700r4 have no problem with the h/hump
some people have trouble with everything. the hei should clear with the stock mounts, may be close but close only counts in horseshoes and hand grenades
ron
Old 02-28-2011, 10:33 PM   #15
BarnFind
Change the exhaust manifolds. Even with chevelle 3/4 length headers, I had to massage the engine stand. IMO the engine moved forward not only works better but, the engine looks right in the engine bay. In the back position, it seemed like I had to run a long water pump and fan spacer to get it close enough to the radiator. When I looked in the engine compartment, I didnt like looking at mostly fan shroud. Sean
Old 02-28-2011, 10:58 PM   #16
Rich 5150 69
Rich 5150 69's Avatar
Try this style it will make life easier, found on 69 and later 350 cars / trucks, plus what I `ve come to the conclusion is some people use differant trans mounts, ( height mounting position) which will dictate how close the disttributor or 700 r4 will reside at the body flange.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 02-28-2011, 11:04 PM   #17
SFTorange
SFTorange's Avatar
I found an exhaust guy who told me it should be no problem to get my original manifolds to work. I'll bring the truck in and see what he can do. I also like the look with the engine forward. I've taken care of everything else with moving it forward, so the exhaust should be the last thing.
Old 02-28-2011, 11:27 PM   #18
BarnFind
You gotta be flexable with the need to stay original. Locating the engine forward is stock for a 1967. Using the stock manifolds for a 67-72 will still have the stock appearance without the exhaust outlet headache. Just my.02 - Sean
Old 02-28-2011, 11:45 PM   #19
SFTorange
SFTorange's Avatar
I have a ton of flexibility, just not a lot of extra money. I might try to look for a set of 67-72 manifolds because I agree it would be easier. I'm just not sure how much they would cost.
I've already sandblasted and coated my original manifolds, and if I can get the exhaust bent up easily enough there's no reason to worry about it. If the original manifolds don't turn out then it's nice to know I'll have a fall back option.
Thanks for the input.
Old 02-28-2011, 11:50 PM   #20
Dusty457
There is also a set of ram horn manifolds that angle back at the flange that probably would give you the clearance that you need that is what was on my 66 and the engine was set in the forward position also. Hope that helps.
thanks Dusty457
Dusty457 is offline   Reply With Quote
Old 03-01-2011, 12:41 AM   #21
SFTorange
SFTorange's Avatar
As usual, you can find out what you need on here with a little research. A lot of guys want to run the 2.5" Vette manifolds on their 67-72 trucks. Those manifolds dump straight down like ours. The following thread shows that a good exhaust guy can make the bend if he knows what he's doing.
http://67-72chevytrucks.com/vboard/s...d.php?t=440965
Old 03-01-2011, 12:47 AM   #22
BarnFind
Here is a pair that need a couple of studs but more than fair price. You should be able to get a pair for this price or cheaper. Just a thought. Sean
http://seattle.craigslist.org/skc/pts/2237754890.html
Thread Tools
Display Modes
