Old 02-28-2011, 11:38 AM   #1
steve'62
steve'62's Avatar
62 motor mount questions
Is there a motor mount kit to switch my 235 to a sbc? Am I able to use the front engine mounts for a 283,or a 327 and where could I find them? I know I need a different bellhousing....a little guidance please
steve'62 is offline   Reply With Quote
Old 02-28-2011, 11:31 PM   #2
steve'62
steve'62's Avatar
Re: 62 motor mount questions
I've seen alot of advice on here but its seems to be mostly for 63-66. Will the 67-72 work on a 62? Does the front engine mount for the 235 work onthe 283?
Old 03-01-2011, 02:07 AM   #3
Captainfab
60-66 Nut
You can use a front mount on a small block, but you need the saddle that bolts to the front of the block. In using this setup you will have to use a bellhousing with the side mounts to keep the engine stable.
I would recomend using either the '67-'72 small block frame brackets or the '73-87 C20 frame brackets. With either one you will need a spacer on top of the frame at both mount bracket.
Thread Tools
Display Modes
