02-28-2011, 03:56 PM | #1 |
6.0 swap, PB vacuum connection??
Here is a picture of what I have. Seems GM stuck a plug in the back of the intake with a quick disconnect fitting.
So I stopped at the dealer today thinking surely they also made a fitting with a hose barb for vacuum assist brakes. I know all these newer trucks aren't hydroboost. Well according to the parts guy, GM doesn't make any sort of hose barb fitting. I find it hard to believe that GM made this intake with a vacuum port, then went through the trouble to design a quick disconnect fitting with a plug,,,and then not offer a hose barb in it's place. Why go through that trouble?? Anyway, I know this swap has been done before,,,,what did you guys do for your 3/8 vacuum hose on the PB booster?? Find a fitting from somwhere else?? Thanks. |
02-28-2011, 04:06 PM | #2 |
LSX addict
Re: 6.0 swap, PB vacuum connection??
GM part # 12559760
-1982 C10 SWB GMC Sierra [undergoing 6.0/4L80E swap with mild restoration] |
02-28-2011, 04:20 PM | #3 |
02-28-2011, 04:30 PM | #4 |
It's a good number on GMpartsdirect. Unfortunately no picture supplied. In any event, I'll run back to the dealer with a number in hand now
Thanks Ksstamp. |
02-28-2011, 04:53 PM | #5 |
LSX addict
probably didnt know where to look an was just trying to get you out the door. ive got one i ordered from GMpartsdirect. havent installed it yet an im not home or id get ya a pic of it tho. no problem! im doin the swap too in my '82.
02-28-2011, 04:54 PM | #6 |
LSX addict
here we go
02-28-2011, 07:10 PM | #7 |
Beautiful, that will do the trick. Thanks again
03-01-2011, 03:08 PM | #8 |
Btw, there is more than one nipple fitting that will go in there....different sizes for different hoses. No, I don't have a part number for you.
You could try our Lsx swap section or Ls1tech, etc. I'll let you know if I run across what I used and what size it was. As an aside, I'm pretty unimpressed with most parts counter people. They just have no initiative. This includes the dealers, autozone, auto salvagers, etc. Thank goodness for sights like these!
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) 2003 K2500HD 8.1/Allison1000/NP263 |
03-01-2011, 07:46 PM | #9 |
Ya, that picture that KSS supplied looks to be about 3/8, and should get the job done for me. I ordered it yesterday.
I like the LS swap section (well scattered for lack of a better description) I've found some usefull information there. My problem is you can look for hours and read through alot of rubbish and jibber jabber before you find what you are looking for, and sometimes you still don't find the answer. Some of those threads are 50+ pages long. What would be nice is to take the usefull information, remove the posts we don't need to clean it all up, some form of spread sheet with Q & A's,,,then make it a sticky. It would take someone days or weeks to go through and clean all those LS threads up like that though It's a pretty straight forward swap, it's just the little junk that you can't find anywhere, (like this vacuum nipple) and I've never read about that really slows you down. I'm making my own motor mounts, Advance Adapters had all the 4L60E swap parts I needed, and even cut me a break on the prices. Most of the other swap parts I'm using from the truck I pulled the engine from, some other stuff I'm making or modifying to work. Such as the factory temp sender. I tapped the passenger side head to accept the NPT size for the factory temp sender. I also purchased the oil block off cap above the filter, so I could also tap that to the NPT I need for the factory 1/8 oil line. I wanted to keep the factory gauges working. There is just alot of little stuff to these swaps that really isn't mentioned. |
Thread Tools | |
Display Modes | |
