Bellhousing for muncie or saginaw
Does anyone know if a sm465 transmission (4 speed floor) bell housing from a 1969 may accept a Muncie or Saginaw transmission without major modification?
'71 Custom/10 Deluxe LWB '71 Custom/30 Deluxe Dually |
Fabricate till you "puke"
Re: Bellhousing for muncie or saginaw
The pilot hole in your truck bell is 5 1/8", vs 4 11/16 for the car. You need a ring to press over the input bearing retainer, to properly center the trans if you use a M20/21/22 Muncie or Borg warner T- 10. For the saginaw trans, you can use the front bearing retainer from a 68 up (truck) saginaw 3 spd. You need to bolt & nut the bottom 2 ears on the trans, as the bottom holes in the bell are not theaded. Also, if you can swap to a 67 or older truck bell, the center hole is the proper size for the car trans. Pretty much bolt in
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
If I use a 65 truck bellhousing can I used a 68up truck saginaw 3 speed?
Thread Tools | |
Display Modes | |
