Old 03-01-2011, 04:26 PM   #1
rolling thunder
tach question
im a new guy here and a new guy to my 81 c10 long bed and i have a question i bought a tach and which wire on the dist. do i clip my green tach wire to? theres three ive got everything else hooked up besides that lol i need to get some pics up later it other than standard rust its in good shape and its looked a ton better since i bought it ha ha
rolling thunder is offline   Reply With Quote
Old 03-01-2011, 05:18 PM   #2
allengator
allengator's Avatar
Re: tach question
Your tach should have 3 wires... 12v, ground, and signal...
I assume the signal wire is the one you are asking about... it should go to the TACH terminal on your distributor if you have an HEI...
Allengator
Outta the Blue
(my band - available for hire in the DFW area!)
1980 Chevy SWB Pickup (build thread)
1951 Chevy Sedan Delivery
2004 Chevy Tahoe Z71
2011 Harley Davidson Street Glide
2018 Silverado Z71 Crew Cab
allengator is offline   Reply With Quote
Old 03-01-2011, 05:47 PM   #3
jasonroman
jasonroman's Avatar
Re: tach question
just put one in myself two days ago.
green when to distributor.
black is ground.
red i put into fuse panel
and the white....
well i put it into a 5 amp instrument light part of fuse panel. and then fuse blew...so i ended up with no lights on the inside of truck.
i replaced the fuse. but not connected the white anywhere yet.
not sure if i can put a bigger fuse instead of the 5 amp. and be ok.
hope that helps.
jasonroman is offline   Reply With Quote
Old 03-01-2011, 05:57 PM   #4
3r!c84
Badass
3r!c84's Avatar
Re: tach question
this.. the coil is now your tach hook up on your hei. everything else is the same
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 03-01-2011, 06:40 PM   #5
rolling thunder
Re: tach question
where is the tach terminal? im bout to go outthere and find it
Old 03-01-2011, 06:43 PM   #6
jasonroman
jasonroman's Avatar
Re: tach question
on the top of distributor cap.
on mine. there was the power<<<<think its power going in on top of cap.
and next to it there is...marked tach. thats where the green will go.
Old 03-01-2011, 08:00 PM   #7
83burban
Re: tach question
The terminal is with all the others on the underside of the tach - just go up from underneath and you will find it. Its location is printed on the coil cover.
83burban is offline   Reply With Quote
Thread Tools
Display Modes
