Old 03-02-2011, 03:05 PM   #1
Gary 70 Jimmy
Gary 70 Jimmy's Avatar
out side spare tire mount
I picked up a out side spare tire mount I need to know if you can get the nuts in the top body mount out of the panels dont look like they come out.
1972 GMC Jimmy 1/2 4X4 4wheel camper
1970 GMC Jimmy 1/2 4X4 350
1969 Chevy Blazer 1/2 4X4 307
1967 chevy LWB 3/4 396
Gary 70 Jimmy is offline   Reply With Quote
Old 03-02-2011, 03:33 PM   #2
Gary 70 Jimmy
Re: out side spare tire mount
Here is what I am talking about do the nuts come out.
Old 03-02-2011, 05:53 PM   #3
cleszkie
cleszkie's Avatar
There is actually a single backing plate in there that has three taped holes for the bolts. Its shaped to fit the inside contour of the outter quarter pannel skin. It it installed by feeding it through the side marker openning. The backing plate should have a rod welded to it that acts as a long handle. I don't have a picture handy, but someone will post up I'm sure.
cleszkie is offline   Reply With Quote
Old 03-02-2011, 05:59 PM   #4
Gary 70 Jimmy
Thanks that is what I wanted to no.
Old 03-02-2011, 06:02 PM   #5
cleszkie
cleszkie's Avatar
That backing plate is not welded in there. If you can locate the end of the rod, you should be able to break it loose from the rust scale that is holding it in there. Good luck.
Thread Tools
Display Modes
