Old 03-06-2011, 08:55 PM   #1
Zonaman
Zonaman's Avatar
Jack Question
I need to pull the trailing arms off my '69 C-10. The only jack I have that will lift the frame high enough for the jack stands I'm using is a farm jack. It fits right into the rear hitch receiver (1/2" thick square steel tube, attached to frame) It has a tongue weight capacity of 600 lbs. I believe this will be strong enough but thought I'd get your input first. Any experience or advice would be appreacited.
Thanks.
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus!
Zonaman is offline   Reply With Quote
Old 03-06-2011, 09:50 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Jack Question
you won't be under it without the jack stands anyways right?
I have no clue what a 'farm jack' is, but if it won't life the light side of a light weight truck, then you shouldn't own it. And if your hitch won't hold the weight, then you need to get rid of it anyways.
Old 03-06-2011, 10:25 PM   #3
cdowns
cdowns's Avatar
Re: Jack Question
if you have a jack that can handle alotmore weight is a whole lot better and safer// if you plan on getting into the hobby it is well worth saving and investing in a quality floor jack
Old 03-06-2011, 10:38 PM   #4
Frkypunk70
Frkypunk70's Avatar
Re: Jack Question
Well.... If you have a "farm jack" then I assume you have a back hoe just lift the whole truck up with that.
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. "
Frkypunk70 is offline   Reply With Quote
Old 03-06-2011, 10:46 PM   #5
Zonaman
Zonaman's Avatar
Re: Jack Question
That's "farm jack" as in 3.5 ton, high lift jack. A pair of 6 ton jack stands will be holding up the back end of the frame while I frolic underneath. Got no farm and no back hoe but I'll use this thing if my receiver can handle the light end of the truck OK.
Old 03-06-2011, 10:57 PM   #6
Frkypunk70
Frkypunk70's Avatar
Re: Jack Question
I was only joking about the back hoe. As long as you feel safe I'm sure you will be fine. I will say I had a old chain reduction system slip on me one time and almost kill me. We were just putting a new rear end under the truck. Whatever you use make sure you have a fail safe this really isnt a laughing matter.
Thread Tools
Display Modes
