Old 03-06-2011, 11:06 PM   #1
rhodog77
rhodog77's Avatar
s10 swappers......fuel neck and gas cap
hey guys,
Im using a the stock s10 gas tank out of a 1991 s10. Im going to run the neck through the drivers side bed side like the '47 and 48's. can you guys tell me what you doing about your filler neck and gas cap. I see that some people are cutting the AD filler neck and cutting the s10 neck and then welding them up to fit their needs. I would like to use the stock s10 neck but I need to find a screw in cap that fits. I can only find the stock plastic ones but I want a chrome one. Does anyone know if any other vehicles caps will work or where I can find a chrome one. I know that some motorcycles utilize aftermarket screw in caps. Im heading to my local harley davidson dealership tomorrow to check the fit. any info would be great. thanks
"Get Busy Living or Get Busy Dying"
1970 P10 Stepvan
rhodog77 is offline   Reply With Quote
Old 03-07-2011, 08:18 AM   #2
2ndGenRR
2ndGenRR's Avatar
Re: s10 swappers......fuel neck and gas cap
i'm also using the original S10 tank in a '48 Chevy and was going to use a '48 style neck (i thought it would be cool to flip it from the passenger's side to the driver's side and see how many people would actually notice), but after getting one and seeing it hanging out of the side i changed my mind and got a hagan fuel door. however, my bed is raised 2" and there wouldn't be enough room to install the door if it wasn't.
the pic is with it tacked together. i also extended the stake pocket because it looked unfinished in my opinion with the bed raised.
The Stable:
1952 GMC 1/2 ton, 5-window...Owned since age 16...that was awhile ago! Torn apart and waiting for my boys to get old enough to help me.
1990 Chevy K5, 5.3L, 4L60E, slowly going back together as my dune truck.
1951 Chevy 1/2 ton, 3-window...building to sell.
Daily Drivers: 1998 3/4 ton Burb with a 6.5 Turbo Diesel and 1994 1/2 ton Silverado.
I grew up in Flint, Michigan so I can't help but to bleed Chevy!
2ndGenRR is offline   Reply With Quote
Old 03-07-2011, 10:41 AM   #3
MrDude_1
Originally Posted by rhodog77 View Post
hey guys,
you have another non-welding option.
you can take the filler neck of almost any truck or older car with the screw on end that you like.
cut it with a hacksaw, and cut the S10s one.
goto a marine (boat) store and they will have special hose designed to connect fuel fillers to the fuel tank. it is very thick, very stiff, re-enforced rubber. I use the Gates brand myself. Buy the correct clamps for it there as well. You will only need enough to go between the two filler necks with overlap.
Its not very flexible, so cut the necks so that the rubber connector has a fairly straight shot.
MrDude_1 is offline   Reply With Quote
Old 03-07-2011, 11:08 AM   #4
jeffs51chevy
jeffs51chevy's Avatar
rhodog,
I don't know if it will shine like chrome, but my s10 is so old that it came with a metal screw in cap (plastic must not have been invented yet). I remember looking through your build, and seeing your polishing skills. I want to say that the cap is aluminum, but I will have to check that. If it is, you might try shinning it up. You can have mine if you like. My s10 was an early 82.
I think I still have your email - I'll send you a photo.
Jeff
jeffs51chevy is offline   Reply With Quote
Old 03-07-2011, 11:54 AM   #5
1952ssr
1952ssr's Avatar
I took my late model plastic cap and took it apart, then I took my original '52 cap and took it apart. With some plastic adhesive I put the two together. Now I can use the new filler neck but have the look of the original.
1952ssr is offline   Reply With Quote
Old 03-07-2011, 11:06 PM   #6
BlueJeep
BlueJeep's Avatar
I cut down my s10 filler neck because it had a rollover valve in it that I wanted to keep, and bought a chrome cap off a 90's model harley for $10 or so. I used the stock grommet out of my cab, but it doesn't fit all that well so I bought a replacement one for a suburban which I think will work better. See my build thread for pics.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 03-09-2011, 09:19 PM   #7
rhodog77
rhodog77's Avatar
hey guys,
thanks for all the info, tips and tricks. I would love to put a nice fuel door in like 2ndgenRR but my truck is way to ratty for that. I checked my local harley dealership, not much help there. Im sure they had what i needed. I went ahead and took apart my s10 fuel cap. It just snapped apart within seconds. Thats was a really good idea 1952ssr.....thanks. I dont have a new AD cap yet. Any tips or tricks on how to take it apart??? thanks again.
brian
1970 P10 Stepvan
Old 03-09-2011, 10:47 PM   #8
BlueJeep
BlueJeep's Avatar
hey guys,
brian
You don't have a good Harley dealership then!
Here's what I bought, $14.99, just make sure you get the one with RH threads:
http://www.jpcycles.com/product/7200650
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 03-10-2011, 05:45 PM   #9
rhodog77
rhodog77's Avatar
yeah I know they were a bunch of screw ups!!! thanks for posting the link up. I will definetly check it out
1970 P10 Stepvan
Old 03-12-2011, 04:58 PM   #10
rhodog77
rhodog77's Avatar
Stopped by the Harley dealership in Cincinnati today. I knew that I would get more help from them then my local little shop. It took a few minutes to find what I needed. I tried about 4 or 5 different caps but finally found one that worked. Here is the Harley Davidison part number, maybe it will help someone else down the road - 61102-83C. The parts guy told me it was for a 1982-1982 FX. It fits perfect. I need to clean the neck and remove the triangular mounting plate and mount the neck. I ordered a stock 47-48 rubber grommet from classicparts but it doesnt fit right so I had to order a "custom" one, hope to have this week. Thanks again for all the help and ideas.
brian
1970 P10 Stepvan
Old 03-15-2011, 10:35 PM   #11
rhodog77
rhodog77's Avatar
Got my fuel neck, sending unit in and wired up and all the fuel lines finished up. Thanks for all the help and ideas about the cap. If anyone needs a grommet, here is the website I got mine from
http://www.electriduct.com/Large-Rub...mets_p_70.html
1970 P10 Stepvan
Old 03-16-2011, 07:43 AM   #12
RootBeer 6117
RootBeer 6117's Avatar
Thanks for posting the link I was looking for some way to hide my wires better and I am stealing your gas cap idea.
Joe
RootBeer 6117 is offline   Reply With Quote
Old 03-16-2011, 09:04 AM   #13
entourageguy
Yellow truck club
entourageguy's Avatar
This is why I like this site. The ideas to get around roadblocks is amazing.
The filler turned out great.
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 03-16-2011, 09:29 AM   #14
2ndGenRR
2ndGenRR's Avatar
100% agree. Nice workaround and looks really cool.
The Stable:
Thread Tools
Display Modes
