Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-07-2011, 06:07 PM   #1
68racer
Yeah baby!
68racer's Avatar
Manual Master Cylinder?
I will be changing my cam later this year and will be losing the power brakes.
Which master cylinder (disc/drum) can I use?
I want an alloy one for weight loss.
I have looked at Wilwood but don't know which size to pick, calipers are '73 with HD rotors.
Also I have seen non-power master cylinders from base models which looked an easy fit.
What have you guys used?
11.37 @116
68racer is offline   Reply With Quote
Old 03-08-2011, 09:07 AM   #2
kpeztruck
kpeztruck's Avatar
Re: Manual Master Cylinder?
Contact Wilwood tech department, and let them know what diameter caliper pistons, and what diameter wheel cylinders. They will point you in the right direction. Paul Baxter
kpeztruck is offline   Reply With Quote
Old 03-09-2011, 12:50 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
As an alternative, I run a Mopar type of tandem master cylinder in my Super Gas car. It has a 1 1/16" bore. The body is aluminum and the reservoir is plastic. You'll need to run a proportioning valved in the line to the rear brakes.
I just noticed you are in the UK...here is a link to the type I have: http://cachassisworks.com/p-373-alum...-push-rod.aspx
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Thread Tools
Display Modes
