Old 03-09-2011, 08:49 PM   #1
cheford
Tubular Control Arms question
Could someone tell me if the tubular control arms are the same basic dimensions as the original control arms? I did a frame swop using a 72 c10 on a 56 f100 and the tracking is too wide, I bought the new modular drop spindles which brought the wheel inward an inch but I still need more as I only have 1/2" tire to fender clearance. I would like to run 18" rims 18x7 with
4.50 backspacing but the rim contacts the lower control arm taking a considerable amount of the turning radius from the truck. I was wondering if the tubular control arms would help solve my problem or can I safely modify my original lower arms. What would be nice is to see a tubular arm pictured beside an original but probably pressing my luck right.
P.S. I've got so much invested in this project I can't afford to stop if you catch my drift
cheford is offline   Reply With Quote
Old 03-09-2011, 09:15 PM   #2
SCOTI
SCOTI's Avatar
Re: Tubular Control Arms question
Depends on the manufacturer. Some make the upper arm longer to reduce the quantity of shims needed when aligning. Is your set-up coils or bags?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-09-2011, 09:27 PM   #3
c10seconds
c10seconds's Avatar
Contact porterbuilt. Nate can hook you up with some shortened tubular control arms.
c10seconds is offline   Reply With Quote
Old 03-10-2011, 07:19 AM   #4
cheford
I've got 1" lowered coils.
Thread Tools
Display Modes
