Old 03-10-2011, 08:21 PM   #1
GMC Guy
GMC Guy's Avatar
Transmission Crossmember
I'm about to have my exhaust done (the right way) and i really want to replace the transmission crossmember i have with one that is more "duel exhaust friendly"
i don't want to pay a shop to route pipe over and under the crossmember i have, just not as clean looking.
i've attached a picture of what i'm after, the way the pipe is routed is exactly what i want. *thanks for letting me use your pic as an example*
what year/model trucks came with this style crossmember? i'd really like to know so i can search the juckyards high and low for one. thanks
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 03-11-2011, 05:49 AM   #2
GMC Guy
GMC Guy's Avatar
Re: Transmission Crossmember
no one knows?
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 03-11-2011, 11:53 AM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
You can look under a 3/4 or 1 ton truck for dual hump crossmember. Trucks in the 70's and maybe early 80's had them.
Best option, make your own. I had one made for my truck. It tucks the exhaust nice up to the underside.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 03-11-2011, 12:08 PM   #4
GMC Guy
GMC Guy's Avatar
i do like the look of yours a lot, but i doubt i can afford to have one made...
and i don't have the tools or skills to tackle that myself. but a few bolts on the other hand, i can handle that
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 03-11-2011, 12:11 PM   #5
lindstromjd
Gentleman Jim owner x2
lindstromjd's Avatar
Is an old C3 Corvette (71-81) crossmember an option? They have holes in them designed for the exhaust to go through them instead of over or under. Just a thought.
1975 GMC Gentleman Jim #1
-357 / 700r4
1975 GMC Gentleman Jim #2
-350 / TH350
lindstromjd is offline   Reply With Quote
Old 03-11-2011, 12:15 PM   #6
GMC Guy
GMC Guy's Avatar
but would it bolt up between the frame rails? and where could i even find one? don't think i've ever seen a vette at a junk yard lol
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 03-11-2011, 12:19 PM   #7
lindstromjd
I honestly don't know... I'd have to crawl under my vette to see what the dimensions between the subframe rails are. Most vettes will be parted out before they ever see a junkyard. The Corvette forums are really helpful with guys parting them out though...
-357 / 700r4
-350 / TH350
Old 03-11-2011, 12:57 PM   #8
bigblock73
yeller
bigblock73's Avatar
the early squares had a flat trans crossmember with small dimples to allow the exhaust to run under. Take a peek under a 73, 74, 75 or so 1/2 ton 2wd...they have them.
bigblock73 is offline   Reply With Quote
Old 03-11-2011, 01:41 PM   #9
GMC Guy
GMC Guy's Avatar
thanks, i'll be on the look out
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 03-12-2011, 10:40 PM   #10
KrazyRay
KrazyRay's Avatar
One of them went up your way
KrazyRay is offline   Reply With Quote
Old 03-12-2011, 10:48 PM   #11
bigblock73
yeller
bigblock73's Avatar
It did, thank you very much. I am going to section that one to lower my trans a little bit. If that does the trick, then the one IN my truck will be for sale.
Old 03-12-2011, 11:48 PM   #12
texasbigbear_wink
texasbigbear_wink's Avatar
They have some at Summit.
87 Chevy R10 LB
02 Nissan Sentra GXE
texasbigbear_wink is offline   Reply With Quote
Old 03-13-2011, 01:55 AM   #13
GMC Guy
GMC Guy's Avatar
you have one like the truck i pictured? if so, i'll send you a pm
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 03-15-2011, 11:30 AM   #14
motornut
78K & 79C Jimmys
motornut's Avatar
my 4X4 78 jimmy has one they both go over duno if thats an option for a 4X2
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 03-15-2011, 12:30 PM   #15
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I bought one for my truck in a junkyard. It came off a 70s heavy half or Big10. I have had it for 4 or 5 years, and it still isn't under my truck. I just moved it from the old house to the new one over the weekend...
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 03-15-2011, 12:43 PM   #16
silvereagle07
silvereagle07's Avatar
Here's a tube kit from suicide doors. It sales for $69.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 03-15-2011, 01:31 PM   #17
killerpickup
I noticed you still have the long tube headers. I found that changing to a mid length header I was able to route the pipes above the crossmember with no problem. killerpickup
killerpickup is offline   Reply With Quote
Thread Tools
Display Modes
