Old 03-12-2011, 09:55 AM   #1
NicoSlam
Vacuum help
I am in the process of connecting the vacuum lines but need a little support. I need to connect the Pcv from the valve cover and the vacuum gauge on my cluster. I have two spots, vacuum port on the intake and vacuum port on the carb (625cfm Carter ). Which connection goes where??
NicoSlam is offline   Reply With Quote
Old 03-12-2011, 11:39 AM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Vacuum help
The PCV is gonna be a bigger line (3/8" or so). So it needs to go to a large vac port. Usually in the back of most carbs. I would hook the gauge up to mainfold vacuum port if it's possible. If not... hooking it up to the carb port will be okay.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 03-12-2011, 11:41 AM   #3
yob2kanobe
yob2kanobe's Avatar
Re: Vacuum help
PVC valve goes to the carb port, vac guage reads manifold vacuum.
yob2kanobe is offline   Reply With Quote
Old 03-12-2011, 12:12 PM   #4
bsteenburg
Re: Vacuum help
Both need direct manifold vacuum source. The PCV is larger hose to pull a greater volume of air from the crankcase. The gauge is the smaller hose, just needs a source to sense vacuum.
Bryce
bsteenburg is offline   Reply With Quote
Old 03-13-2011, 08:04 PM   #5
NicoSlam
Re: Vacuum help
thank you guys for the help. I usec a 3/8 barb fitting and connected the PCV valve to intake and connected the vacuum gauge to te port in back of the carb. thanks again.
Thread Tools
Display Modes
