03-14-2011, 04:45 PM | #1 |
A day late and $1 short...
Advantages of the 73-87 front suspension?
Besides the 5 lug conversion, what are the other advantages of swapping to the 73-87 front suspension?
Also, is it better to convert the original 12 bolt to 5 lug or swap in a 10 bolt out of the 73-87 chassis?
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
03-14-2011, 08:15 PM | #2 | |
Re: Advantages of the 73-87 front suspension?
73-87's are easier to source parts for. 73-87's are cheaper to source parts for. The thicker rubber of the 73-87 bushings isolate the chassis from noise/vibration better then the earlier pre-73 rubber-lined steel bushings. As far as the rear housing, if you swap in a 10-bolt from a 73-87, you still have axles w/@ best 24yrs of service life (bearing wear), you have to do the labor for the swap, plus you'll possibly have to remove & fabricate new bracketry. Swapping in conversion axles is by far the better choice unless your rear housing is trashed & someone is offering a fresh 10-bolt.
03-14-2011, 11:35 PM | #3 |
All good points. Thanks for the info. What about rear brakes? Will 73-87 brakes bolt up to the 12 bolt? If you are going to have the axles out anyway, might as well change the backing plate if it would work. That would make servicing the rear brakes just as easy.
03-14-2011, 11:52 PM | #4 |
Yes they will also interchange. From the ones I've messed with, there wasn't much (if any) difference unless swapping the HD rear brake set-up. The backing plate is different for the HD set-up. When I've done 5-lug convesions, I bought parts for a 71-72 truck & used the early 6-lug drum backing plate w/o issue. The only 'custom' parts were the 5-lug axles; everything else was 71-72 spec'd.
03-18-2011, 03:59 PM | #5 |
Just a car guy
I swapped to 73-87 front, but went with cpp 6 lug rotors so I did not have to touch the rear.
Things I noticed, A Arms are physiclly bigger. Bushings are bigger ( I swapped in poly urathane), ball joints are bigger, tie rods are bigger.... you get the point.
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
03-18-2011, 05:33 PM | #6 |
Disc brake parts are 'heavier duty' vs. drum stuff.
03-22-2011, 01:55 PM | #7 |
One thing to watch for is the 73-87 Pickup and 73-91 suburban---the track is wider, so watch your front fender clearances, I think 3/4" per side so a total of 1.5" wider.
Thread Tools | |
Display Modes | |
