Old 03-15-2011, 02:39 PM   #1
swiftwater15
New Poster with Differential ID question
I'm restoring my grandads '72 Fleetside, the truck I learned to drive in. I'm trying to Id the rear axle. It was a ranch truck with 64k original miles, but most of them at about 10 mph bouncing around the dirt roads.
12 bolts holding the rear cover. "GM60" cast into the front driver's side of the casting. "NF3896838" cast into the passenger side casting. Five bolt axles, with 16" rims and heavy spring options.
If this a Dana 60, GM 12 bolt or . . .?
Thanks in advance. Tried a search and didn't find an answer.
Dan
swiftwater15 is offline   Reply With Quote
Old 03-15-2011, 04:02 PM   #2
kwmech
Re: New Poster with Differential ID question
1/2 ton? 3/4 ton. A Dana 60 cover will have 10 bolts. 12 bolt will have 12 bolts
kwmech is online now   Reply With Quote
Old 03-15-2011, 04:33 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
a GM 12 bolt. It's a 1/2 ton truck.
Old 03-15-2011, 07:47 PM   #4
DANTIP
DANTIP's Avatar
If you want more information about the gear set, you can look for the axle tube stamp as shown in the sketch (don't pay attention to the casting numbers on the sketch, I borrowed them from a Camaro or Chevelle web site). The stamped code will have the axle code and a coded plant and build date. If you find the stamped code, post it and someone will look it up for you.
DANTIP is offline   Reply With Quote
Thread Tools
Display Modes
