cab mounts?
does anyone have a picture of how the cab should mount to the frame? I just got my bed put together and the bed sits up about an inch higher then the cab if you follow the body lines the cab is lower then the bed. it's kinda hard to see in this picture but here is what I mean
ΜΟΛΩΝ ΛΑΒΕ Last edited by straitnate14; 03-17-2011 at 06:29 PM. |
Active Member
![]() Join Date: Jul 2007
Re: cab mounts?
Mine does too..
LMC has a good break down picture but here's a pic of my rusted truck. |
Re: cab mounts?
2 wd or 4 wd? An inch is a lot!
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Re: cab mounts?
2WD I also cut the frame to make it a SWB
ΜΟΛΩΝ ΛΑΒΕ |
Re: cab mounts?
do you have new cab mounts? if not they might give you the inch youre after. otherwise, you'll have to shim up the 4 cab mounts and the 2 core support mounts to compensate for the difference.
1971 C-20 350/350 |
Re: cab mounts?
I'm going to shim the cab and core support up since the cab is on brand new mounts. I measured the difference last night and it's 3/4 inch not 1 inch so that's not as bad but oh well.
ΜΟΛΩΝ ΛΑΒΕ |
Re: cab mounts?
Since you shortend the frame, didn't you have to relocate your rear cab mounts?
If so, do you think it's possible you went too low w/ them? Just a thought... I plan on shortening my lwb this summer and am interested in what hurdles I might encounter. Not to change to topic, but have you or what do you plan on doing w/ the drive shaft (shorten and run two, or single)? |
#9 | |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: cab mounts?
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
#10 | |
Re: cab mounts?
Oh and I checked my mounts to make sure I didn't mount them to low and there good I just going to do what ironangel did and double up the rear mounts and see what happens I jacked it up to see and it looks good but we will see when I get some more mounts in.
ΜΟΛΩΝ ΛΑΒΕ Last edited by straitnate14; 03-18-2011 at 09:15 PM. |
Thread Tools | |
Display Modes | |
